Question about Canon imageRUNNER 400S Copier
Canon ir 400
When i insert paper in the stack bypass the machine does not detect the paper second problem is after a few copies the machine shows no paper in the first tray the tray has to be removed and put back then it works for another couple of copies please give me a solution for this
    Sniper:
  • 103 Answers
Switch off machine
Open the rear cover then you see the green board
right hand up side it calls dc board remove all connection
re insert them.
switch on copier.
If problem exist replace the board.
Posted on Oct 27, 2008
I need copy A3 with Canon iR 2016j Black and White Copier
Press aditional function, slect copy setting, then stack bypass, then select paper size A3.
Apr 04, 2013 | Canon iR 2016i Black and White Copier
Canon iR2022, now: "drum is
check the drum insert flag in the drum unit(front side).it has to be intact as it has to match the sensor when the drum unit is inserted. u can see it when u insert the drum unit it is it at the front of he machine.u can also bypass it by placing a paper int the sensor
Jul 21, 2011 | Canon iR 2016i Black and White Copier
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
How to solve 2side paper jam its in continue but 1 side is working good...how to solve this problem? its ir 400 canon machine
open the front cover and clean the duplex rollers with alcohol and dry it.
Also, if you have stand for these copier, on the left side of the stand there is opening on top of stand where the copy is going when it copy second side, check for any opsticles in there.
Hope that helped
Aug 06, 2010 | Canon imageRUNNER 400S Copier
Can A3 300gsm paper be used for a double-sided print run on this machine
Canon IR C3200 Published Specifications:
Acceptable Paper Weights
Cassettes: 17 lb. Bond to 110 lb. Index
(64gsm - 209gsm) and Transparency
Stack Bypass: 17 lb. Bond to 140 lb. Index
(64gsm - 253gsm) and Transparency
Jun 16, 2010 | Canon imageRUNNER C3200 Copier
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Canon imageRUNNER 400S Copier Logo
122 people viewed this question
old marine
old marine
Corne Viljoen
