TOSHIBA MK1234GAX USB Device given Error performing inpage operation.
I'h problem with my External hard drive. When I plug it to my laptop it was working properly after that I unplug the drive and plug it to do some work on it but is not accessing. it is showing in USB device detected but it is not showing Driver Icon so I can't access the file from my external drive.
after some time when I tried to access the same drive thourgh Command line it gives me "Error performing inpage operation." message means it detect the drive but it is not allow me to access the files, pls give me solution it is very urgent.
Product name and model is "TOSHIBA MK1234GAX USB Device"
Beni S-P
  • 1006 Answers
SOURCE: Can't detect my HD properly
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 26, 2007
amusedgeek
  • 787 Answers
SOURCE: Not Detected on PC
Since you say that it is detected in Device Manager and is shown as working properly, it would appear that the problem is that it is not getting a drive letter. Have you added anything recently that might take up a drive letter like a flash drive? If so, try removing both and then plugging the WD back in. If this is not the case or does not help, do this:
Assuming you are using XP.
Right click on My Computer and select Manage
The computer Management window will open, click on Disk Management
Do you see the WD in the window on the right?
Does it show a drive letter?
If not, you can assign it one by right clicking on it and selecting Change Drive Letter and Paths ...
If the WD does not show up in Disk Management, possible problems are:
1) USB cable is damaged, try another one.
2) USB circuits in the WD case not working properly, hard drive can be removed and put into another case.
3) WD USB case is good, hard drive is good but there is a loose connection inside. Open case and reseat everything.
4) WD USB case is good but the hard drive inside has gone bad (worst case scenario)
Posted on Sep 27, 2008
jcoady
  • 79 Answers
SOURCE: V:\ is not accessible Error performing inpage operation
To expand upon what ikkenom said, this will work much better done from the command line.
(Assuming Windows XP)
Click "Start", "Run...", type "cmd" and click [OK] or press [Enter]. From the command line type "chkdsk V:\ /F". You can optionally include the "/R" option to check for bad sectors on the disk (Be patient, this will take a long time, especially if there are bad secors).
If this fails, add the "/X" option. This dismounts the volume before proceding. You may need to reboot afterwards before examining the drive.
A MS article describing this error implies that is is likely a physical disk error and the technical reason why the error mistakenly implies a paging fault: http://support.microsoft.com/default.aspx?scid=kb;en-us;141117
I know how distressing it can be to loose pictures and video you've worked so hard to acquire/produce. Good luck!
Posted on May 31, 2009
  • 3 Answers
SOURCE: USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Posted on Aug 06, 2009
SOURCE: phillips external hard drive
My Philips External Hard Drive isnt showing on my computer and is making a clicking noise. I have had problems with my DVD/CD part of my laptop could this be why?
Posted on Jan 22, 2010
External hard dirve toshiba Mk1234gax i pluged in but not responding
the simplest thing is change the usb cable or check it some other system also
Jun 19, 2011 | Toshiba MK1234GAX 120 GB ATA-100 Hard...
I pluged my external hard dirve toshiba MK1234GAX but it is not showing in my pc
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
I have external toshiba harddisk MK1234GAX .when i connect to my laptop its not detecting only red and green light blinking..its not showing on my computer..i need all the files in tht hard disk..please...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 21, 2011 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Toshiba MK1234GAX 120GB hard disk creating problems
Hello, verified if your hard disk is properly installed in the closure, don't forget to format your hard drive in NTFS. if your problem persist maybe need to check your USB connections in device manager.
Jul 10, 2010 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
E: is not accessible Error performing inpage
dirve e not open there is problems of error performing inpage
Mar 10, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
I was restoring the system in my laptop and I have forgoteen to unplug the external hdd toshiba 120 gb mk1234gax hdd2d16. After I have choosen to restore the system of the laptop have initiated, I...
it sounds as that you have flashed the usb port. take the harddrive to someone with a computer and plug it in theirs. if it still does not work remove from case and plug the harddrive straight in to yours.
Dec 04, 2009 | Computers & Internet
"Error performing inpage operation" - External drive
hi
run this command from command prompt
Administrator>chkdsk e(your drive letter): /F
if problem persists just post your problem again..
as soon as possible you problem will be solved.
have a nice day
May 19, 2009 | Iomega Computers & Internet
I've just fixed the problem of error performing the inpage operation by using old DOS command CHKDSK <driveletter> /F. And, i'm satisfied with the MS-DOS command.
Jun 18, 2008 | Computers & Internet
USB Hard Drive Problems
HI,
I have a TOSHIBA MK1234GAX USB Device.
My USB Controller finds it an I see it in my computer devices, but it do not gets a hard drive letter, so I can not access to my files on it.
Yesterdey it worked properly.
Can You explain me what happend and how can I get to my files?
Jun 13, 2008 | Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
HD PROBLEM
Have the same problem with
Did You solved it?
Jun 13, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
