Question about Panasonic NV-DS60 Mini DV Digital Camcorder
Panasonic NV-DS60 hello, i saw your "really easy fix" about wiggling the ribbons, or what ever... anyway, my problem is this: when i try to record/playback, the wheels move super fast and the display and time also moves super fast. it also makes very loud noise.. could you help me, please? do i need to do your fix, or is there something else i should do? thanks in advance.. =]
  • abera_m1 Oct 20, 2008
    yes
  • PanaReparMan May 11, 2010
    Best thing...start with the easiest potential fix first.
    Give the cable ribbon wiggle a try, you never know...
    It sounds like it could be a terminal fault - but, is there a loud clicking?
    Have you cleaned the heads?
    Is the battery slow charged (on the manufacturers battery & charger)?
    -Can you run it from mains - do all the issues remain?
    Has it got wet, or even damp (left in a cellar or roof-space)?
    Post back your results.
    Cheers
5 Suggested Answers
SOURCE: connecting my nv-ds60 to my computer
i need drivers for panasonic nv-ds60
Posted on Mar 02, 2008
SOURCE: Panasonic NV-DS60 Mini DV... red icon flash Problem
je domande le driver de NV-dS60
Posted on Apr 03, 2008
  • 33 Answers
SOURCE: it's me again with the Panasonic NV-DS60
OK, so we're getting closer!
I find that those with problems that manifest themselves on closing the cassette door are related to a loose ribbon connection(s).
Sorry, no pictures, I fixed mine and sold it!
When I say run from mains, I mean there was a cable in the original box that connected from the charger base into the camera, to give it a constant electrical supply; you can remove the battery and run it like this.
This was just to prove that the battery hadn't gone haywire and simply caused a malfunction.
Personally, at a guess, I would definitely open it up and wiggle the ribbon cables, while you're there you should also clean the moisture sensor...just incase.
1. Cleaning the moisture sensor:
Take the base cover off by removing the 4 screws (3 on base - 1 under LCD). There will be two small copper contacts under this cover toward the top/middle. Either just blow on them or if that does not work clean them with alcohol spirit or similar, put the think back together and power up and that should do it - worked for me.
2. Ensuring ribbon cables are seated correctly:
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you'll be happy then!
Good Luck
Posted on Oct 16, 2008
charcois
  • 763 Answers
SOURCE: Connecting NV-DS60 to a computer
it should be connected with a computer because almost all camcorders have a connection to it by using USB. First install the CD driver from camed with your camcorder's box to your computer and after that connect it with a USB. it should be recognize the camcorder after you insert it. you can check also your camcorder's manual.
thank you for using fixya
CHARCOIS
Posted on Feb 19, 2009
Dew symbol on panasonic NV-DS60
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Nov 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Me again =]
The riboon cable connections are circled in red, do (wiggle to ensure they are pushed down into the connector as far as possible) the two on the left of the picture first then test, before closing the case back-up. If this fails to fix your problem, repeat wiggling the remainder of the ribbon cables. Test again.
Should this fail to provide the required results, then we can look at the moisture sensor.
Let me know how you get on.
Cheers
Oct 22, 2008 | Panasonic NV-DS60 Mini DV Digital...
Connecting my nv-ds60 to my computer
plisss send my draiver camera video panasonic NV-DS60
May 06, 2008 | Microsoft Windows XP Home Edition
FLASHING ICON WONT RECORD.
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Dec 25, 2007 | Panasonic NV-DS60 Mini DV Digital...
Power lamp blink
Turn the cam over.
Nov 22, 2007 | Panasonic NV-DS60 Mini DV Digital...
Power Light blinks
Turn the cam over.
Nov 19, 2007 | Panasonic NV-DS60 Mini DV Digital...
There is a red on and off icon on the sceen
Turn the cam over.
Sep 04, 2007 | Panasonic NV-DS60 Mini DV Digital...
Panasonic nv-ds60
Turn the cam over.
Dec 03, 2006 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
49 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
