Upgrade BIOS My computer keeps crashing when any pen drives or ipods are connected when the computer comes back on it says it has recovered from a serious error and windows says consider BIOS upgrade
  • msmaniac May 11, 2010
    What Laptop/Desktop are you using?
    BIOS upgrade depends on the motherboard model so would be fine if you let us know the motherboard model for your PC.
    thank you.
I have a QTech desk top PC i don't know which motherboard
Posted on Oct 14, 2008
How can I recover my
Flashing a motherboard's BIOS can have many positive purposes and can help keep a motherboard compatible with changing technology.
PCnineoneone.com says that a proper BIOS flash can introduce enhanced features and bug fixes for the motherboard.
However, a bad BIOS flash can be devastating to a computer owner and very difficult to recover from.
If the proper preparations are made and all instructions are followed, a bad BIOS flash can be corrected.
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back.
Remove the jumper from its normal position on the motherboard and place it in the recovery position.
Usually, the jumper will need to be moved over one space to cover a previously exposed prong.
Locate the BIOS CMOS jumper on the motherboard, usually in the bottom, right corner.
The jumper consists of three metal pins facing upward and is usually marked with "CLR_CMOS" and has a plastic cap over two of the pins.
Check your specific motherboard manual if you are unsure where the jumper is.
If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect.
Insert the BIOS flash disk and power on the computer.
If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer.
Since there will be no video, listen for the internal PC speaker to beep.
This means it is performing the BIOS upgrade.
Power down the computer once the BIOS upgrade has been completed.
This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished.
Without video, the only way to be sure is to listen to the PC speaker.
When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off.
Replace the jumper back in its normal position and put the side panel of the computer back on.
Power the computer on.
If the computer turns on as normal, the recovery was a success.
or
How to Recover My Laptop BIOS
The BIOS is the basic input/output system on your computer that normally runs invisibly in the background, yet it's required for your computer to perform even the simplest task.
When something goes wrong with the BIOS, you might have difficulty even booting your computer.
There are a number of things you can do to recover a laptop BIOS that has gone wrong, ranging from relatively simple to somewhat costly.
Recover your BIOS by restoring the manufacturer settings as the first line of defense.
Reboot your laptop, reading the on-screen startup messages to determine what key you have to press on to enter the BIOS (normally "Esc" or "F2").
Press on the key when required to avoid booting into the main operating system, going instead to the BIOS screen.
Locate the item named "restore default settings" or "restore manufacturer settings"
(or something along those lines) within the BIOS.
Select this option using the arrow keys and pressing on enter, confirming when requested by pressing on the "Y" key.
This restores all of your old BIOS settings, potentially recovering your laptop BIOS with a minimum of fuss.
Send your computer back to the manufacturer or to an authorized dealer if restoring the factory default settings doesn't work.
The technician removes the old, faulty BIOS chip, replacing it with a new chip if possible.
It may also be a problem with the battery connected to the BIOS, which is always removable.
In many cases if the BIOS itself is the problem, the entire motherboard must be replaced since the BIOS chip is rarely removable in a laptop.
Hope this helps
Oct 31, 2012 | Computers & Internet
After copying into pendrive files are damaging and corrupting and also showing okb of every file what is problem and show me to how to recover from that it is new pen drive
download a data recovery program and use the program to scan the pend drive and recover lost files. I used a file recovery program called asoftech data recovery before, quite easy to use and works well for me, you may download and have a try.
http://www.asoftech.com/adr/
Sep 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How can we repair a USB which is crashed like a hard disk.
Dear i have send some information of solve your problem. I hope you have satisfied my suspicion if you can solve your problem you can read this information
Thanks.
Pen drive is the best way for people who are looking for larger space to store their important data and want a compact, easy-to-operate storage drive. These pen drives are mainly trendy among system and network administrators. They can load a large amount of information about configuration and software that can be used for the system maintenance, recovery and troubleshooting. But what if there is a problem with your pen drive having important documents have been crashed? Ddipr.com releases new USB repair software to ensure user to get back files and folders stored in USB pen drive.
Pen drive data recovery software securely restores lost digital images, office documents, database files, audio, video files etc from your damaged and logically crashed USB pen drive.
Ddipr provides advanced and professional USB repair application to recover missing or erased files and folders lost due to accidental deletion, virus attack, software malfunction or power failure etc from corrupted or formatted pen drive. Kingston pen drive files undelete utility easily restore data from various USB drive (flash drive, memory stick, jump drive, thumb drive, key drive) and many more USB drives. Thumb drive data restoration program provides reliable and secure method to recover all digital files format including midi, ppt, doc, pdf, mov, xls, jpg, gif, mp3, wav, exe, bmp etc. Software support pen drive in all capacities including 512MB, 1GB, 4GB, 8GB, 16GB, 32GB and even higher capacity drives. USB drive data backup utility support all leading brands like Kingmax, Samsung, Sony, Toshiba, Jet flash, Apacer, Lexar and many more. Software easily installs on all windows operating system such as Vista, 98, 2000, 2003, XP, ME, NT. The software development team of ddipr.com combines a variety of advance features in this particular software. Some of the important features are:
- Pen drive data salvage program recovers data even if Drive Not Formatted message is displayed on your computer.
- Software provides GUI interface which makes it easy to use and operate.
- Application supports all versions of windows like Vista, 98, 2000, 2003, XP, ME, NT.
- Software provides easy data recovery from logically crashed or inaccessible pen drive.
I am a company representative and fully satisfied with this application to restore deleted data from formatted or corrupted USB pe
Feb 16, 2010 | Kingston Technologies 512MB DataTraveler I...
Needs help to recover crashed asus r2h bios
You need to put the battery back in, try to find an IDE floppy drive to use and if the new bios version hangs then download the old BIOS and reinstall that -a computer that hangs is not a successful install or the upgrade is wrong. Pulling the battery doesn't revert to the old BIOS, just default settings for the BIOS installed. Using a USB floppy for this is not a good idea as the usb drivers must load -might as well use a thumb drive if this is a laptop. For a desktop stick with the basic IDE floppy drive. Best of luck, Steve Medley
Nov 07, 2008 | Computers & Internet
My flash drive is faulty and i want to retrieve my data
dont panic, try this data recovery program called asoftech data recovery.
I used the program before, it helped me recover my files from pen drive. If it does not work, you may try quick format the pen drive and then use asoftech data recovery program to recover again your files.
Oct 10, 2008 | Computers & Internet
I/O Magic Giga Bank 4GB portable drive crash
Please tell me the method of creating bootable pen drive.
And also suggest me what are the contents in CD come with Trnscend pen drive.
Are there any software useful for making bootable disk in CD????
Apr 16, 2008 | Computers & Internet
Computer crash!
Try using the boot disk to boot the system and then enter fdisk /mbr to fix the master boot record. It doesn't destroy any data on a computer. There is a professional data recovery businesses that could probably recover that data - but at a cost. They are expensive and advertise in PC Magazines. Take care because there could be a lot of rip-off merchants in this business. In future, buy two hard drives ans use the free XXCopy from http://www.xxcopy.com/ to clone your system from one drive to the other. A good way to back-up your system is to get a second hard disk of the same or greater capacity, and use the free XXCopy from http://www.xxcopy.com/ to make a clone of your system. If the BIOS allows it, you can then set the BIOS to boot to the alternative drive to run the cloned system, format the drive containing the defective system, clone the cloned system back to the main drive, set the BIOS to boot from the main drive, and you are back in business. You can keep the spare hard disk drive stored in a safe place ready to be reinstalled in an emergency, or to update the cloned system. You install XXCopy according to the instructions that come with it. To clone the C: drive to a D: drive enter the following command in the Start => Run box - xxcopy c:\*.* d:\ /clone It is as simple as that XXCopy will open a DOS window and clone the c: drive to the other drive specified in the command. Read the article on how to use XXCopy to clone a system here - http://www.legge40.freeserve.co.uk/Tips.htm.
Jan 30, 2006 | Apple iPod nano
Computers & Internet Logo
David Payne
David Payne
