Sony LCD TV
I have a Sony 32 inch LCD TV model KDL-32XBR6. The TV works great, but I have trouble with the video when I switch to a component source inputs. There is a delay sometimes with the video that can take as long as 3 to 5 minutes to lock in. I can hear the audio, but the display says - No signal. Check the external input or select another input.
The s-video and HDMI input sources come on right away. The old components only have the s-video and YPbPr outputs. The TV is only several months old. I'm not sure if it's the TV or does this particular model have this problem?
  • Dennis Carey Oct 17, 2008
    Since it is still under factory warranty, I'm getting it fixed at a local authorized Sony dealer.
  • Dennis Carey Nov 09, 2008
    I got it fixed at the local Sony service center. They had to replace the BU board. Part No. A1547083A
  • 81 Answers
Hi.
I would advice you to check your circuit board. If the Tv is some months old then maybe it is under the warranty. Get it checked at a service center. This is not a problem with this particular model.
Hope this helps.
Regards  Faraz
Posted on Oct 14, 2008
    Genius:
  • 1,550 Answers
Check the circuit board and look for cold solder joints or cracks in the solder.
POWER LIGHT DOES NOT GO ON (KDL-32XBR6)
The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 27, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Our Sony Bravia Model KDL-32XBR6 wont open. The stand-by light continuously blinks.
Know how to solders?Power supply board have dead capacitors.Take the tv aparts,look for Capacitors that puff up or burst open.Replaced these capacitors well get ur power back.Or buy and replaced the whole
refurbish power board at Shopjimmy.com,Ebay.com.
Jan 23, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
What does the six blink error code mean when on a
6 blincks is protection code. Service tech needs to diagnose problem because failure could be from inverter board to panel itself.I'm sorry I can't do better than that.
Nov 22, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL 32S5500 TV When left on standby overnight locks-up, hangs.
There is a Post on the Sony Support site which I hadn't previously found. Basically there is a software bug which has come about apparently due to Freeview transmission changes. In order to stop the the machine locking up disable the 'Automatic System Update' option. A Sony centre will apparently apply a software fix to properly resolve the issue, fine if with warranty period, maybe pricey if not. I will get the fix but haven't yet done so as the workaround of disabling the System Update option works.
Sep 18, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
