Question about Microsoft Windows Vista Ultimate Edition
ERROR MESSAGE ( 0xc 0000135) log on.APPLICATION ERROR
LOG ON
  • Anonymous Oct 14, 2008
    vista can restart
  • 158 Answers
Run ccleaner
www.ccleaner.com
install it and run it
and go to msconfig
startup
unselect the all programes
Posted on Oct 14, 2008
Setup.exe is not a valid win22 application
You may see Windows error code 193 (%1 is not a valid Win32 application. (Code 193)) when you are starting a Windows Share Point server or a Windows Exchange server. The error message will also generate general Service Control Manager messages in your system logs, too. Error code 193
Aug 27, 2012 | Remington Rem Mod 715 308 Win 22
I allowed a download to watch movies from my laptop to be placed on my computer. When I received it back it would boot up and return to my main screen. A message box pops up headlined by lsass.exe -...
You have downloaded a program that has a malware and this virus has made changes to your system OS. Now the best thing to do is to remove the downloaded file, if you are not able to do this the OS must be reinstalled.
If the PC is responding then clean up all the internet history, browsing and cookies by choosing tools, internet options. Also try and restore the PC to an earlier date.
Jul 02, 2011 | Sony VAIO VGN-A600 PC Notebook
Hp c7180 getting message ocx1a002f, any ideas?
Are you sure the error code is not 0xc....
It sounds like your C7180 has an internal error condition and may need to be reset. It may be easier for you to view this solution online from HP support:
An 0x.. error message displays
Dec 21, 2009 | HP Photosmart C7180 All-In-One InkJet...
Receive error code 0xc 0000135
Your operating system may need microsoft .Net framework. Check windows update. When it loads do not run Express, click on Custom. Download
.Net framework in order if possible. Continue the same untill Custom no longer shows updates for .Net framework.
Here is a microsoft link for error 0xc0000135. http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=error+0xc0000135
Happy holidays!
Mike
Dec 11, 2009 | Microsoft Windows XP Professional for PC
Blacberry 8110 i deleted a folder and now the only thing i have no icons on my phone, it shows applications, call log and messages, when i got to applications all these go away and nothing happens, i can...
I would like have clarification on the error message, wheather it is error JVM523 or error 523 application reset.
Thank you for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | RIM BlackBerry 7290
0xc 19a0022
Not enough information provided by poster.
What is the exact model of the printer and who is the manufacturer?
Just as a FYI the error codes are in Hexadecimal. This is signified by the "0x" prefix. The codes are "C1 9A 00 24 and "C1 9A 00 22". Without the make and model of the printer you cannot track down the error codes.
Don
Oct 22, 2009 | Office Equipment & Supplies
Error message 0xc 180001
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on.
If it then turns itself off again, turn it back on; it should start the calibration sequence (it takes about 5 minutes) and when it finishes, you should have a working printer again!
Apr 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Application errors
Uday,
May i know when exactly do you get this message.At the loggin in or while opening some application.
Aug 25, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows Vista Ultimate Edition Logo
559 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
