I have a tsstcorp ts-l462d dvd/cdw combo drive factory installed in my compaq presario c501nr notebook. i cannot properly format cdrw media. only 5544mb of 700mb cdrw formatted. i used both STAPLES AND MEMOREX cdrw media. how can i fix and get all 700mb formatted.
  • finishnow Oct 14, 2008
    correcion to above: only 554mb of 700mb formatted.
    i have a tsstcorp ts-l462d combo drive factory installed by my oem on my compaq presario c501nr notebook. i have a problem formatting cdrw media. only 554mb of 700mb availabele after formatting. i was told this was due to the creation of file allocation tables.
    however when i format CD-R media i have no such problem. all 700mb are available after formatting. it seems i can use any CD-R manufacturer's media.
    please explain why there is such a difference between formatting cdrw vs, cd-r media.
  • 859 Answers
You will never be able to format the entire 700MB of any RW media. This is because the formatting requires a file allocation table be created and this takes up a lot of room. The data stored in this table is for addressing file segments by cylinder, track and sector. If you have a floppy disk you will notice on the diskette drawer slide it states it is a 2MB diskette but when formatted you only have 1.44MB of usable addressable space. The same is true for any formatted RW CD.
Just how much space is available after formatting a RW disc on your system depends in part on your software. It is possible to have as much as 645MB of usable space on a RW CD. Every software program is a bit different.
I hope this helps you to understand why you see this downsizing of your RW CD's usable space after formatting.
You can also bypass proprietary software and just use Windows. You paste your files to the CD drive and you'll notice a new top section in the file window pane that is titled "Files Waiting to be Written". You have to right click the right hand side of the Explorer view of your drive and then select the command, "write these files to disk". You'll probably end up with more usable space by letting Windows format it for you in this manner. However, it does depend in part on your drive's maker.
Posted on Oct 14, 2008
  • Glenn Rogers
    Glenn Rogers Oct 15, 2008
    Data written to a CD-R is written much like a phonograph record, it is in one contiguous line of data with file header information that states Start of File, End of File and the file name itself inside that header. Because it is written in this manner, without the need for a File Allocation Table you will get nearly all 700MB of space as usable. Note that you will not be able to put 700MB of data on a 700MB disc. You can try this as a little experiment is you want, you just receive another error message as to disc space.
    Another good example of this loss of storage size as advertised is in Hard Drives. A 500GB Hard Drive will not even come anywhere close to the advertised usable space once it is formatted, but when you see your drive in the System, it will be labeled and described as a 500GB drive.
    I do understand this is somewhat bewildering and we computer users, builders and owners have to accept the fact that this is the way it is and move on with the knowledge of what space there is available in spite of labels.
    Some software varies on its approach to reserving file space on a CD-RW. Some reserve more and others less. My suggestion is to use Nero if you can afford it. There are free CD Writing/Formatting software titles out there but some leave a great deal to be desired. As a shopper it is buyer beware. However, the maker of your CD-RW media will have no affect on how much file space is available or not.
    Best Regards,
My DVD/CDW-ROM drive is gone! It is a TSSTcorp TS-H552D How can I down load a new driver free?
Try the following link;
If that doesn't work I suggest you install a free program called "Slim Drivers" and allow it to scan your system and locate the correct driver. I recommend noting which drivers you're installing so they can be rolled back should one of them not function properly.
Feb 19, 2011 | Gateway GT5408 PC Desktop
Hi! I have a Dell Dimension CDW/DVD stopped working...the drive wasn't being recognized at all. So I replaced it with a TSSTcorp CDW/DVD TS-L462D-0...didn't help...still not recognizing my...
Did you use the same SATA/PATA cable as from the last one? If you have a different cable try that. Also if its a PATA(also known as IDE. usually a flat wide cable) cable try switching it around maybe its backwards. Verify its getting power, are there lights? does it open?
After you have tried all that reboot. if windows detects the device you should be good, may just need to update the firmware from disc or from the TSST website. If windows does not detect it you can try to search manually using the add remove hardware wizard in the windows control panel. If none of this works, as crazy as it sounds... you may have another defective drive. Trying a known good one will see if thats the problem.
Hope this helps.
Jan 26, 2011 | LG SecurDisc 20x External Double-Layer DVD...
My tsstcorp cdw/dvd TS-H492C rom is not being displayed on my displays a message... Dat is windows successfully loaded the device driver for this hardware but cannot find the hardware device....
I see this is a month old,but I'll answer this for anyone doing a future search that may come across this thread.
The link is to Microsoft's on-line repair center.This will fix several error codes,including 41,and is probably the first thing to try when your optical drive is installed but Windows can't find it.
If this helps with your problem,and anyone in the future,would you rate my post please?
Jul 12, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
TSSTcorp CD/DVDW TS-L632D ata dvd drive doesn't burn!!! Vista HP
Most of the time MEMOREX brand is not compatible with HP.
Try a diffrent brand and check if it works.
Jun 05, 2010 | HP Computers & Internet
TSSTcorp CDW/DVD driver model h492a dont work HELP
Use the following link, scroll a little and click on Fix It
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If the problem remains, use the following link
Click Run Now
See if it able to detect any problems.
Mar 13, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
TSSTcorp CDW/DVD TS-L462D Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
What windows is this?
Who is the maker of the laptop?
  • Turn the computer off, remove the DVD drive and restart.
  • look for the drive in device manager
Windows xp – Start button>run> type devmgmt.msc
Vista/Windows 7 – start button> in the search box type devmgmt.msc
  • Remove or un-install the cd/dvd drive
  • turn off the computer
  • Put the drive back in
  • Restart the computer
  • Install your driver or allow the driver to install
If it continues to fail then either replace the drive or look in the component's properties, click the drivers tab and delete these drivers from windows system32 folder. You will need the windows installation disk to restore these drivers.
Jan 24, 2010 | Acer Aspire 5315 Notebook
My TSSTcorp CDW/DVD TS-H492A driver is not reading DVDs
my tsst corp cdw/dvd ts-h492a is not reading any dvd's how do i fix this problem without having to spend $29.99 for another program?
where can i download the drivers for this drive?
Nov 14, 2007 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
