Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
Water trickles out of sprayer head on pull out faucet.
Soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine. Thanks for help
  • crossroadsjm Oct 15, 2008
    Thank you. I called Price fister and they are sending a new cartridge. Your solution is right on tho and I wil do that as it wony arrive for several days. God Bless you. gena
  • Anonymous Mar 13, 2014
    cold water in stream
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi crossroadsjm,
I'm Harvey the Master Plumber.
Your problem is: soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine.
It is very possible that some debrie has come up in the water and is partially clogging the faucit. For this you would have to turn the water off and disassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
Water hesitates to flow when turning on plumb works brand kitchen faucet. Also, side sprayer barely flows.
If you have good flow elsewhere, then the problem is probably in the faucet aerator. Remove it and clean out debris. As for your sprayer. Does it have a lot of white scale around the nozzle? If it does, remove the spray head(screws right off) and soak it in vinegar for two hours. Now, take a toothbrush and unclog all of those holes.
Jan 15, 2017 | Plumbing
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Jul 14, 2010 | Blanco Classic Single Handle Faucet with...
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
I have a kitchen faucet by hansgrohe, 06801860. When I turn on the water, some of the spray comes on, when I press for the spray, a thick stream of water comes in the center. I would love to have spray...
your sprayer ''picks up''it's supply from the flow to your faucet.spray heads wear out & are not repairable.replacement hose & sprayer assembly can be found at home improvement stores.if you can see the other end of the hose where it attaches to the faucet,it's not too hard to replace.you don't have to turn off the water at the meter.
Sep 22, 2009 | Plumbing
Our delta kitchen faucet with the sprayer and faucet all in one started losing pressure 48hours ago and it is down to a trickle now. We have taken it all apart and can't find a blockage. Any ideas?
Point your water line into a bucket and turn the water on at the wall. If you get a good flow, we'll go back to the faucet. No kinks in the supply lines, right? The reason I ask is this was reminiscent of a recent problem where my friend could get hot water to the faucet, and it would slowly go down to a trickle. The problem was that the supply hose had a bit of a kink in it, and got choked off when the line got hot.
OK, good flow into the bucket. Sometimes the supply lines can delaminate, and choke the water off as well. Since you have a sprayer faucet combo, make sure that the flex hose that dispenses the water, and has the weight on it to retract the nozzle back up doesn't have a kink either. Remove the spray nozzle, and try the faucet, holding onto the hose. It's possible that the spray selector could have a problem, so check the spray head and diffuser. With the water on, push the sprayer button, and see if the problem might be there. Remove the aerator on the end of the sprayer, and check the screens for pluggage. My guess is that the issue is in the spray head.
Best regards, --W/D--
Aug 12, 2009 | Delta Plumbing
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
501 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
