Num an scroll lights on on key board
My pc num lock is stuck on trying to fix it now both num and scroll lock is on. Thanks
  • 1 more comment
  • maddieJ Oct 15, 2008
    my scroll lock is on and i can't take it off
  • The Waterboy Jan 05, 2009
    turing on the numeric key pad on an aluminum wired keyboard?
  • jahnfar Jan 12, 2009
    same problem - i am stuck in num lock on gateway laptop
Same happened to me. restarted my computer and it went back to normal. except for the light above the key is still on
Posted on Oct 24, 2008
How do I control lock keys
The keys above the Function keys (Num Lock, Scroll Lock, maybe speaker volume or display brightness) will be in a different color than the white keys on your keyboard. Usually they will be blue or orange. There is a corresponding function key, usually left of your spacebar, that is in the same color, and it is usually labeled FN.
Press and hold the FN key and press the Num Lock key. Then release both of them. That should turn off your Num Lock.
Nov 01, 2014 | Computers & Internet
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
My Compaq laptop keyboard seems to be stuck in ALT mode. All the keys which have an alternate character in the upper right corner, will only type those characters. For example, the "m" key will only type...
Never ran into this problem myself but a friend of mine has. He said what fixed his what holding Fn + Num Lock and it remedied his problem.
Unless your key is stuck/broken you can also try a can of air and try to blow it out and or pull the key and make sure its not stuck down.
But deff try the holding Fn + Num Lock method first.
Jul 18, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Boots up with function key locked. Can't type normally.
It sounds like your NumLock key is on. Try pressing the FN key and the NumLock keys at the same time. This should straighten things out.
Aug 17, 2009 | Compaq Presario X1000 Notebook
I may be totally retarded but I have no clue what the padlock with two arrows in it. It is on top of my keyboard next to the lighted indicators for num lock and shift lock.... anyone have any idea what...
The scroll lock key was meant to lock all scrolling techniques, though it is no longer used by almost any software. In the original design, scroll lock was intended to modify the behavior of the arrow keys. When the scroll lock mode was on, the arrow keys would scroll the contents of a text window instead of moving the cursor. In this usage, scroll lock is a modifier key like ALT and SHIFT (which modify the function of other keys) and, more specifically, a toggling Lock key like NUM lock or CAPS lock, which have a state that persists after the key is released.
Regards;
Hassan
Jul 22, 2009 | Fujitsu LifeBook N7010 4GB 320GB HDD PC...
Num Lock Light Wont Work
the led either burned or became un-soldered from the board. the labor to fix it is not worth it in my opinion un-less you can do it yourself.
Jun 04, 2009 | Dell Inspiron 6000 Notebook
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
My acer aspire 3690' s key pad locked. please explain how i can unlock it.
try the following:
  • press scroll lock/num lock, if no success then
  • press and hold fn key then press scroll lock/num lock, if even no success then
  • press and hold shift key then press scroll lock/num lock.
and please post your feed-back
Thanks
Iqbal
Apr 20, 2008 | Computers & Internet
Function keys not working
try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard. Most laptops have a light that will turn on and off when you do this, indicationg that the funtion keys are in use. depends on the brand
Oct 24, 2007 | Computers & Internet
Computers & Internet Logo
466 people viewed this question
David Payne
David Payne
