Question about Linksys Wireless-G WRT54G Router
Connecting 2 wireless routers
I have a linksys wireless router connected to my dsl and wanted to extend its wireless connection to another far place outside my house. So i bought another linksys wireless router to connect it to the first wireless router.
What shall I do in terms of IP address, etc (all technical things which I am not very familiar with) so that I can connect to the second wireless router. On the first, I can connect using OBTAIN in the IP address option. I can browse the net in the process. On the second, I cannot. I tried connecting a cross over cable from wifi1 port1 to wifi2 WAN port. Then I also tried connecting cross over from wifi1 port1 to wifi2 port1. This time it worked bu intermittently, after my friend entered IP addresses. But he is not here anymore.
How do I set up the 2 wifi routers so I can extend the connection?
Thanks
rtserrano
    Genius:
  • 1,269 Answers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Posted on Oct 14, 2008
SOURCE:
I have an N900 router that I want to secure from outside the home use
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 11, 2013 | Linksys EtherFast Cable/DSL Router
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Connected to the router but router cannot connect
Assuming no other changes to your environment first try restarting everything - from the outside in. Start by restarting the cable/dsl modem, then the router, then the computer - allowing each to completely reset before going to the next.
You might also want to contact the provider to check availability in your area - in case there are known outages in your area.
Jul 04, 2009 | Linksys Wireless-G Broadband Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless Network
You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
Hope that helps........
Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
223 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
