Question about Hamilton Beach Water Cooler with Storage Cabinet
Hamilton beach water coller
The hot water side stop working,no hot water
  • 2 more comments
  • Anonymous Oct 28, 2008
    no hot water hamilton beach
  • vicki44116 Feb 05, 2009
    I have the same problem. Hot water works fine. The cold however just trickles out. Was making louder than usual noise for the past week or so. Tried cleaning but didn't help.
  • ajmorn Feb 09, 2009
    My cooler wont heat the water. the cold works just fine. i cleaned the unit and it still isnt working. any ideas?
  • Anonymous Mar 08, 2009
    I have the same problem. Hot water side simply quit making hot water. Hot water light no longer comes on. Cold water side works fine.
  • 750 Answers
Hello chattie wm,
Welcome
You said, the hot water side stop working,no hot water
This is usually one of five things.
  1. Check that the power is on at the breaker and the cooler has the proper light lit up that shows you it is on.
  2. If you have had it a while, (year or more) it may be that the heating element is covered
with minerals from the water which if it's hard water can happen too!
3.The heating element may be bad and need to be replaced.
4.The thermostat may be bad.
a.How old is it ?
b. What did it cost to buy?
You do not want to spend more than half what you payed for it to repair it!
Let me know how it goes and what you decide.
Thank you for using fixya,
Huum....Please remember to leave a rating!
Posted on Oct 14, 2008
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
where is the relay switch for the watercooler model #8733o
Jun 21, 2009 | Hamilton Beach Water Cooler with Storage...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing.
May 27, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
305 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Dan Webster
Dan Webster
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
