Question about Bosch Kitchen Ranges
I have just moved and have inherited a Bosch gas hob. (E-Nr:PCL985FGB/01) (FD: 8606/00249). Out of 6 burners only the bacl left one lights. It is clean and the gas comes through when I turn the control knob for the required seconds but on release of the knob the gas flame goes out. Please can you help> I thought I'd inherited a porche and have ended up with a Robin Reliant! many thanks for your time. Bev
    President:
  • 1,462 Answers
The fault probably lies with the thermocouples but unusual that so many should go faulty
Posted on Oct 14, 2008
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
Hi, can sb please help I'm looking for a user manual for my w/machine Bosch E-nr # WFM2010/08 in English. Thank you
According to Bosch (http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html) it's not yet available online. You can order most original instruction manuals through the Customer Service Replacement Spare Parts department by calling 0344 892 8979 (UK) or (01) 450 2655 (ROI).
Jan 20, 2015 | Bosch Washing Machines
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Gas hob is very difficult to start. have to hold
I've just had this prob on an inherited (just moved into new house) A2. Thought I was losing the plot as followed instructions to the letter re starting gas hobs. Got an engineer in to give the ecking thing a general service & told him about the hob. He said I wasn't pressing the knob hard enough. If you press the knob enough to make the ignition click, press the knob a bit further (it will go a bit further "in" honest). If you do that it should start like a good 'un (I felt sooo daft). Something to do with magnets!! Anyway, give it a try (this works for me unfortunately I've had the damn inner glass on the main oven go pop - yes, infront of an engineer twice in less than ten days. Knobs aside, I'm starting to go off this cooker. I want to cook to eat not have a "pretty" in the kitchen!).
Apr 12, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Ignition on gas hob fails sometimes on certains burners
open the hob covers with a screw driver and check the wires that carry the spark are intact and haven't been chewed by a rodent ie (RAT/MOUSE) like my one had been :-)
Apr 28, 2008 | Rangemaster Proffessional 110 Gas Kitchen...
Kitchen Ranges Logo
194 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
