Question about Russell Hobbs Kitchen Appliances - Others
Heater Element Replacement
I need to replace the heater element but understand the parts are not available!? If this is correct will another model simular to this one fit? Surly Russle Hobs use the same heater element on many models?
  • 417 Answers
Yes I think they do but these may also be unavailable. You could try sourcing 'after market' replacement elements, these are universal fit elements often from the original suppliers and cheaper too. Try searching the web for Russell Hobbs replacement kettle elements.
Posted on Oct 14, 2008
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ... > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
What does code h1 indicate?
H1 ie a HEATER fault, which usually occurs after the fill and just as the machine is about to start heating the water, when your machine detects that the heater has gone "open circuit" . This is probably a failed heating element(There is a break in the wire inside the element) . I can't be specific because you don't mention the model number, but washing machine heater elements are usually available on eBay or from your local white goods supplier fairly cheaply (You will need a model umber to make sure you get the correct one). Replacement is not too difficuly. There are many many YouTube videos available with instructions
Sep 25, 2015 | Samsung Washing Machines
Part number for standard heating element for eco smart 11.3kw?
Go to
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
Mar 18, 2015 | Element Water Heaters
Water heater elements for 2006 conquest trailer
Remove the old element. Take note of the water heater make and model, i.e. Suburban SW6DE or Atwood GC6AA. You can find the replacement at your local RV parts department. I have even seen them at Lowe's. Or you can buy one online.
Apr 19, 2014 | Gulf Stream RVs
Replacement element part # for 83VR52-2
Look at watt rating printed on end of each element.
Elements are generic and available at hardware store.
You do not need special element. Just match the wattage, or choose less wattage, do not choose higher wattage.
Might pick up both thermostats too.
Oct 10, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Delonghi toaster elements are losing their heat
There are three likely problems:
1. The toaster and/or heater elements need to be cleaned. If they get coated with food material they will not function correctly.
2. The heater element could just be going bad. You would need to search the web with your model number to find the appropriate replacement part then open up the unit sufficiently to disconnect the old elements and replace the new elements. You need to ensure that the connections are correct because loose connections would not permit sufficient electricity to enable the elements to heat up.
3. The thermostat could be going or gone. This controls the amount of power provided to the elements and thus determines how much they heat up. Again, you would need to search for replacement part.
Aug 11, 2011 | Vacuums
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
If upper element is burned out the tank will not heat any water.
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
Nov 23, 2008 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Kitchen Appliances - Others Logo
908 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
