Question about Microsoft Windows Vista Ultimate Edition
Windows wista can not support full screen mode in turbo c installation
When we are trying to install turbo c it can shows the message
like This system does not support fullscreen mode.
  • 1 more comment
  • Anonymous Nov 15, 2008
    trying to run a game and it tells me it doesn't support full screen mode
  • theboogeyman Dec 01, 2008
    I'm trying to play a game. You can try to open it in compatibility with Windows Xp. Tell me what happens.
  • kmblack Dec 25, 2008
    when i install games it tells me that it does not provide full screen mode.i am using windows vista home premium
Help me how to put os
Posted on Nov 15, 2008
    Genius:
  • 1,605 Answers
You need to contact vendor.
I believe the porgram is make for 800x600 cressn size.
Posted on Oct 14, 2008
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
1. How to install and run turbo C++ 4.5 on Windows 7 (32)? 2. How to run Turbo C++ 3 on Windows 7 in full-screen mode?
I had similar issues with an old version of Turbo Pascal.
I used a program called DOSBox which emulates the older machines the packages were designed for.
http://www.dosbox.com/
It worked very well including full screen.
Feb 23, 2011 | Borland Turbo C++ 4.5 Full Version for PC
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
Now , Type in the following commands after the Z prompt:
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
About installation of Turbo C in vista operating system
I have an easier solution. Please check my blog for more details http://cybercomments.blogspot.com/
Nov 10, 2008 | Computers & Internet
Turbo c++ in vista
Step 1: Open TC++ (normally C:\TC\BIN\TC.EXE). In the startup it will show a dialogue box that it
doesn’t support full screen mode as seen in the picture below.
Just select ignore option. Then it will open the small screen mode
Step 2: Go to the top left of the window and click. It will show a menu as shown in the figure.
Then select properties from the menu
Step 3: Now it will show the properties window, in which you select the Font tab.
There you can see two font options as Raster and Lucida Console. The default will be Raster.
You select Lucida Console and select the size from the size list as 28.
Step 4: After selecting the fonts, now you have to select the layout tab where you can see
screen buffer size, window size, and window position options.
First unselect the “Let system position window” option from window position options.
Now make the following changes:
Screen Buffer Size: Width: 82 Height: 28
Window Size: Width: 80 Height: 26
Window Position: Left: -4 Top: -4
OK
comments @
roxy111in@yahoo.com
Oct 19, 2008 | Computers & Internet
hi!!!!!
download the latest updates in turbo c plus
or download C++ for windows vista
Sep 19, 2008 | Microsoft Windows Vista Ultimate Edition
How to install turbo c in vista home basic compaq pressario lapto??
how to run turbo c in full screen mode on vista operating system.
when i am running turbo c it's gives  a message that vista not support full screen. what should i do please suggest me.
Sep 13, 2008 | Compaq Presario Notebook
ABOUT TURBO C++
Vista doesn't support full screen mode while operating Turbo C++,
and its also doesn't support graphics(bgi) while operating it.
There are lots of compatibility problems with Vista --
I have Vista Home Premium and have warning when I start VC++ 2005 Express!
I just tried running tc.exe and did not get the warning message you reported.
Although it would only run in the small window.
Your best bet is to download either VC++ 2005 Express or Dev-C++.
They both run full-screen.
Sep 10, 2008 | Computers & Internet
Turbo c doesnt have a full screen version on vista..
FOLLOWS THESE STEPS TO SOLVE THIS PROBLEM...
  1. Copy the “DOSBox0.72-win32-installer.exe” from http://www.download3k.com/Install-DOSBox.html
  1. Install it with default settings.
  2. Create a folder “Turboc” in your C:\> directory.
  3. Copy your turbo c folder such as “TC” in the folder “Turboc”. This is shown in the following diagram.
fifth.jpg?w=625&h=526<!Run the software you installed. Its icon is present on the your desktop.
  1. This will run the software, as shown in the fig:
first.jpg?w=573&h=507<!
Write these lines in the screen:
mount c c:\>Turboc
Press Enter
Following message will appear on the screen
Drive c is mounted as local directory c:\Turboc\
Now write:
C:
Press Enter
Now write:
cd TC
Press Enter,
Now write
cd bin
Press Enter,
Now write
Tc.exe
All these steps are shown in the following figure:
8.
Now following screen will appear:
10. Press Alt + Enter. Full screen mode of Turbo C will appear.
[updated]IMPORTANT : Don’t use shortcut Ctrl+F9 bcoz it is a shortcut for dos box to exit
Happy Coding
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
636 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
