Question about Samsung YP-Z5 MP3 Player
Samsung YP-z5 won't connect to the PC!
I've had my YP-Z5 for about nine months now, and some time ago it started getting weird. At first, I noticed that my background reseted to the default, blue one every time I restarted the mp3. The clock in the upper-left corner also changed from 24h-format to 12h each time as well. Also, the only way to reach my songs are from "Browse Files" (The Recordings are still there though). I've tried to press the reset button several times, but it won't help any. The worst problem is that the mp3 refuses to connect to my PC! When I plug it with the USB-cord, it says "Connecting..." like usual, but instead of changing to "Connected" it zaps back to the menu where I can listen to music. Every now and then, it makes a new attempt at connecting, but never succeeds. I can still charge it, though. It worked perfectly fine before, and we haven't really done anything with the PC since then. ANY kind of help would be very appreciated! cannot connect to the computer. there is power going throught the USB cable but it does not register antwhere on the system i have exatly the same problem. everthing is working fine, only when I want to get the system info, it change back to the main menu.
  • 1,031 Answers
Try the following
1) Pressing the reset button.
2) Switching the device to UMS mode - whereby the pc should recognise it as a removeable harddrive
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Posted on Oct 14, 2008
    Sergeant:
  • 352 Answers
(1) Download version 2.37 of the Z5 firmware from HERE.
ttt
    Genius:
  • 1,447 Answers
Hi-
If software reverted to its original settings without changing it, chances are there is a corrupt system, if you want you can either flash your MP3 by going to this LINK but since you posted that the product is still 9 months old, better call manufacturer so that they will guide you on how to troubleshoot it step by step and you will have a chance of getting a replacement if all fails, you have a one year warranty with your product, if you open or burn it by flashing, they might void the warranty for it.
Hope this helps
    Sergeant:
  • 208 Answers
It is likely to be a conflict with a Windows upgradeon the PC.
You can try this hotfix and try to connect again.....
http://support.microsoft.com/kb/920875
Let me know how it turned up....
Thanx for using fixya...
    Master:
  • 763 Answers
Sir, try to format your phone to become a new system again or reset default settings.
CHARCOIS
  • Samsung Master
  • 6,487 Answers
First thing you can do here is to reset the unit to its default settings so all settings will be clear and that will help fixing this problem....and also try connecting this unit to a different computer and check if it will be conencted fine because if it will stay connected to you can update of flash the software for this ....
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Nov 29, 2009 | Samsung YPZ5FZB 1 GB, BLACK, MP3 Player,...
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Connection to my computer
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
oh i think i might know the solution
connect something else like a usb disk to ur computer when it does go to the right bottom corner of the screen where the time shows. then u should see a green arrow on something black icon. double click. that thing shows that ur usb is connected then connect ur mp3 to the computer it should work...but it might not
if u hear that ring noise as soon as u connect that mp3 to the computer u are safe but u have to try other things...
Sep 29, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
306 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
