Question about Ovens
Oven smoking hi,hope you can help me!my smeg oven (even after a good clean!) smokes when ever im cooking something.Is there a vent or something which could be blocked or something?!just cooked a roast chicken on a low heat but whenever i open the door to check it theres lots of excessive smoke issuing!!!!could you advise me of this...?many thanks smoking oven
  • kb-bear Oct 16, 2008
    i have a problem with simpson electric oven smoking
    and the things i bean told to do is not put the baking
    tray to high up in the oven as this will make it smoke
    if it is to close to the top element you have to put on
    lower rack and allway have flat tray under the baking
    tray as will catch any spillage ending up on the botten
    element you allso use oven bags thay help with spater
    on the elements i hope this is help full
    President:
  • 1,462 Answers
Smoke is caused only by fat getting onto an element and should stop after a while, ie when all the fat is burnt off. this is usually a problem with the grill element.
you can get a finjhe mesh grid which fits over the centre vent in the back plate and this should help
Posted on Oct 14, 2008
2 Suggested Answers
SOURCE: oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
Posted on Dec 05, 2007
Smoke is coming from between oven and microwave especially when it's on self clean very foul oder
Very likely you are cooking some thing vegetable or animal that has been left over inside the stove. If you wanted to keep it, you might try to take it outside and let it burn off, this might take weeks. If you wanted to take it all apart, you might find the problem, although you might wish you had not.
God bless your efforts.
Jan 18, 2016 | Ovens
My gas range/oven emits a toxic smoke that burns our eyes WAY different than spilled food. The smoke comes out the right side vent rahter than the usual left side vent and only when we cook higher than...
When the oven gets dirty and you don't run the clean cycle, dirt builds up and burns away the hotter the oven gets. Run the clean cycle if you have a self clean mode on the oven. throw the metal burner and grates in the oven too. (no plastic) open a window because it will stink and it takes a few hours to run. If not, use oven cleaner then run the oven to the hottest temp for at least 1-2 hours to burn the old dirt out..
Good Luck, Bill
Jan 07, 2018 | Ovens
Excessive smoke comes out from oven when cooking
hmmm sounds a bit strange is there anything at the bottom of your oven that has been spilled on it even on the heating coils? (if electric) (if gas there could be a very serious problem with the oven that needs fixing right away!)
Dec 17, 2017 | GE 30" Built-In Single Electric Wall Oven...
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Smoke coming from electric oven element
if it is the upper element is smoking when in use then its usuall grease/fatty deposits that have attached itself from previous cooks.. the only way to rid is to open doors & windows then turn to max temp to burn off... 5-10 mins usually suffice dependant on quantity. looks bad initially but soon it will be heating clean again..
Dec 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
Jan 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Oven smoking
Nov 12, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
1,270 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
