Sony Handycam CCD-TRV615 Camcorder
Problem for Sony Handycam CCD-TRV615 Camcorder
Sony camcorder won't eject tape
By Luisa_K - usenet poster
I have a Sony CCD-TRV615 camcorder which gives me an error code C:32:00
after I inserted what I suspect to be a bad tape (gave me similar results in
a different Sony camcorder). Now I cannot eject the tape. The camcorder's
eject button causes no reaction. Does anyone know if there is a way to
remove a tape from this type of camcorder without using the automatic eject
mechanism? Can the camera be partially disassembled without damaging
anything? Are there any websites which might give this kind of information?
Thanks.
Same Problem
Feb 28, 2009
-   I have the same problem-I can't remember the error message and I have a Sony Digital Handycam, model number DCR-TRV22E. The cassette compartment goes up and down slightly. The camera cannot record anything. I've already taken it to a camera store who tried to look at it and couldn't do anything, but not to a repair place.
I have a new camera, so I can record new footage, but I want to get the tape out of this old camera. I need to be able to use the old camera afterwards, because the memory stick function still probably works.-   Guest
Apr 30, 2008
-   I had the same problem, displaying the same code, the tape carriage was **** 1/2 open and won't budge open or close. I disassembled most of the camera trying to get to the gear mechanizm and polked lightly at the small gears by the motor through the opening on the tape side, this must have moved it enough to free it up. I got it to operate when I had it disassemble, actually it's still apart I'm having more trouble trying to get the side covers to go together. Try removing the plastic cover over the tape carriage and if you can take a small thin screw driver and move the gears, don't take the camera apart.
Good Luck-   Guest
Apr 19, 2008
-   error C:31:42-   Guest
Feb 09, 2008
-   Hi, my cam corder is driving me insane, its chewed up a couple of my tapes and now is not working. as soon as i go to put a tape in it's beeping at me and displaying C31-:23. After chewing the first tape the tape compartment didn't want to open up to give me my tape back, after a bit of shaking and jiggling i finally got it out. Can anyone please tell me what C31-23 means. I also tried a cleaning tape just incase the heads needed a clean however it hasn't workrd-   vengo
Jan 08, 2008
-   I am having the same problem, the tape won't eject (and it is my friend's tape too!!). I took the battery off but have no idea where the "reset" button is.-   leanneh
Best Solution
posted on Jan 29, 2008
Very Helpful)
COURNANE1
Rank: Apprentice
Rating: 100%, 5 votes
It probably has to do tape reels mis aligned, hit it a few time on the side where the tape is.
This has worked for my Sony Hi Camera
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Dec 10, 2007
Very Helpful)
artsylady03
Rank: Apprentice
Rating: 100%, 1 votes
I had a tape stuck in my TRV17 for a couple of months. What finally worked was to remove the battery, then put it back on. Then press the reset hard with a very strong pointed item. In hindsight, using compressed air to gently blow out any dust might have helped too.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 10, 2009
Not Rated)
nwilms66918
Rank: Master
Rating: 84%, 11 votes
hi ho
Was this helpful?
Yes
No
Solution #4
posted on May 27, 2006
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
Take it to an Authorized repair center. They should be able to unload it
with out causing any damage to the camcorder. It does take some disassembly
and knowing were and how to apply a small voltage. More than a layman should
take on.
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam CCD-TRV615
Questions and Unsolved Problems for Sony Handycam CCD-TRV615
Do you recommend Sony Handycam CCD-TRV615 Camcorder?
Answer
Answer
need to download video from camera?
Answer
when i record on auto focus will not stay focused.
Answer
can see myself her computer says needs to be configured to receive
Answer
I have a problem with this fairly old Sony CCD-TRV615 camcorder. When I turn on the power, initially... (More)
Answer
When trying to copy from the sony to a DVD to transfer home movies, the tape needs it's picture... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam CCD-TRV615...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
