Question about Fisher and Paykel Dryers
Fisher & Paykel dryer won't stay on
I have just bought a 2nd hand F&P dryer (model ED54-F) which at first seemed to be operational. However, now that I have it at home it is apparent that something is wrong with it as it will only run for about 30 seconds before stopping and making a beeping noise. I thought that this was a part of its humidity sensing function, but it still does this with a load of wet washing, and also when it is set to just run for one hour without the sensor. Does anyone have any ideas what the problem could be, and even better, any solutions?
Thanks a lot!
  • 92 Answers
SOURCE: Dryer Fisher paykel
the biggist problem with dryers and drying is the outside vent being plugged. next thing is it gas or electric. electric i would think cycling thermostat. gas would be coils or thermostat. this is asuming you do have heat
Posted on Jan 20, 2008
SOURCE: Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Posted on Dec 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: I have a Miele dryer, model T494C. The system
It's most likely one of the heat/humidity sensor tubes that needs to be replaced. This has happened twice to my T494C in 12 years. Miele (or your dealer) will come out and replace it for a cost. Do NOT leave wet clothes (or semi-dry clothes) in the dryer for any length of time when the dryer is not operating. Apparently this is one of the problems.
Posted on Apr 16, 2010
SOURCE: need a manual for fisher and paykel drier ED56
try here http://kitchen.manualsonline.com/ex/thread/view/idThread/2200997
cheers Sandy
Posted on Jul 02, 2010
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
How can I find out the part number for a bearing on my fisher & paykel dryer?
Your model number might be DG62T27GW2.
You can get a user manual from this site.
http://www.ajmadison.com/ajmadison/itemdocs/3969_USA_EN_Smartload_Dryer_UC.pdf
To find the part numbers from Fisher and Paykel parts catalogue you need the serial number or product number of the dryer. This should be on a sticker on the inside of the lid. Once you find it go to this site and download a parts manual.
Appliances User and Installation Manuals Fisher Paykel
Sep 03, 2014 | Fisher and Paykel Dryers
Fisher-paykel GW712-AU
unplug. remove lid by opening and bumping to one side. two screws at front of machine under rubber covers. lift top gently, remove bowl ring, 8 clips and one spring. unscrew agitator. you can now remove the inner bowl and clean. theres not filters in this machine.
Dec 04, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel ED54
check door switch
Nov 29, 2013 | Dryers
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
How much does this model weigh?? (MSD2454GRW). Just bought one 2nd hand now need to transport it it home. Any advice on how to lift it into back of pickup truck??
its a model not made anymore but most weigh between 200 and 450. the more gadgets, the more it weighs. It is a side by side so id guess around 250-275, youll need a couple hands
May 18, 2011 | Maytag MSD2454G Side by Side Refrigerator
Hi My mw512 fisher paykel washer won't Drain,how do i remove the drain pipe at bottom of tub? it won't seem to just pull off, des it need to be turned? cheers Michelle
I have a model 11, but I believe they are the same. The end at he outlet of the pump actually has tabs on it. Just twist and pull. Make sure the tabs are ligned up with the slots before you pull too hard.
May 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have KitchenAid Superba 2001 42 in side by side Refrigerator.. It has no model number because the previous home owner who bought the refrigerator apparently bought it as second hand or scratch and...
Open the refrigerator door and look for a LABEL . they have never made one that did not have it someplace .without a model ,NO ONE can assist you except perhaps a repairman that comes to your home
Sep 08, 2017 | KitchenAid Refrigerators
Open Questions:
Dryers Logo
118 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
