Tv will swit on and off by its self - Televison & Video
  • 49 Answers
Loose connection..poor solder in power supply and horizontal circuit
Posted on Oct 14, 2008
Back passenger power window stopped working
I can help with a little testing. On the hinge side of rear passenger door, should be a wiring harness. Probably has a protective rubber boot covering, pull the covering back far enough to get at wire colors in the diagram. One wire is voltage the other is ground depending if the window is going up or down. Use a test lite to check. Key on, I would think.Your front passenger window works ok? If the wires check out good for voltage and ground, could be something wrong with window motor?
Oct 22, 2017 | Cars & Trucks
My gauge fuse blows when start engine
disconnect the gauge,put new fuse in and see if it blows again.
the will be a chort in the fan off the gauge or on/off swits.
if he blows again disconnect the swits.
May 04, 2014 | Chevrolet Blazer Cars & Trucks
The fan or blower motor is not turning when I switch air conditioner on.
MY AC UNITE IS ARCHING OUT SIDE THE CURCUITE BREAKER IS TRIPPING OFF
May 20, 2010 | Goodman CKL36AR36 Air Conditioner
Swit problem don't listen to radio
Some options are available in the phone........
Apr 01, 2010 | Nokia 6600
My tv has power but no volume, what could be wrong
the speaker is busted or maybe the tact swit.ch of volume is defected
Feb 11, 2010 | Quasar SP-2719 27" TV
Iqc60h95w zenith=hitachi i can set up convergence but when i press swits on the main board to retorne the picture the convergence wont stay on memory.witch butons on the remote i have to press before press...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Zenith IQC60H95W 60" Rear Projection...
Your Television was design so that channel 91 is a dedicated swit
try hooking it up in the back of the set then use the channel down button on the set and go past 2, it should come up with the inputs at that stage
Jul 15, 2009 | Emerson EWF2704 TV
My Encore 802.11g is not working. I have misplaced the install disc or manual.
hard wire your pc to the modem using ethernet cable
download this manual...installation guide HERE
Jul 07, 2009 | Encore 802.11g Wireless Cable/DSL Router...
No headlights or taillights
check the fuse and relay
Nov 14, 2008 | 1990 Chevrolet C1500
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
