Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigirator not cooling up
My refrigerator is not cooling up and no ice maker my kenmore coldspot side by side stainless refrigerator has been making the clonking noise for months now, it clonks consistantly every hour or so, and today the freezer is not cooling nor the refrigerator. All the lights are on and it seems to be working however its not cooling. The center partition between the two doors has been VERY hot for months also. I took alot of lint and dust out from the gate below the doors, could all of this lint contributed to blowing out the cooling device.
My kenmore freezer on top model is freezing food but the ice cream is soft.
Posted on May 02, 2009
Most probably it is your coils are filled with lint and dirt. Yes, you need to get a brush (they sell a lint brush to clean the coils) and more importantly the pipe of a vaccum or a shop vac and take out the bottom piece under the fridge and clean the coils as best you can. Also pull the fridge out and vaccuum any open space you can get too from the back (pull up the cardboard and clean behind it). Push the fridge in and out a couple times, vacuum again. Hopefully you should then be good to go.
Posted on Nov 03, 2008
    Genius:
  • 1,122 Answers
You need to pop off the gate and really get under there with a shop vac,is the fan in the freezer working?can you pull the frig out to see if the compressor is running,you can put your hand on it to feel if it is running(watch it it might be hot,the only other thing is it might be stuck in defrost,can you find the defrost timer and manualy take it out of defrost,let me know what you find and we can go from there-mike
Posted on Oct 14, 2008
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot side by side. The ice maker is not working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Nov 18, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
The ice maker has stopped working, the motor is co...
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
243 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
