Question about Acer Aspire 5002WLMi Notebook
Display problem there is display problem im my laptop. When I start my laptop, desktop in pink color..Whenever i try to open anything all windows also in pink color only...Os is WIN XP...In Display flickering also there...Give me solution as soon as possible.
    Sergeant:
  • 306 Answers
Posted on Oct 14, 2008
Recover ur hard disk drive
Display loses color after start up turning black & white
I wouldn't think that was the problem I would check the settings.
Mar 17, 2014 | HP G60-120US Laptop
The colors of my laptop's sreen are inverted. I've tried everything I could think of (display settings, system restore,....), how do I fix this?
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Feb 28, 2013 | Dell Latitude D820 Notebook
How to replace display
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Note
hope this helps
Nov 20, 2012 | Computers & Internet
I want to factory reset a mini 10 but screen is broke(i am using t.v) im afraid to start the process and then not be able to see anything after
Yes that could be horrid. Try setting the tv as your only screen. If you go to l settings Navigate to the "Start" menu, and click it once to open it. Select "Control Panel." Click "Adjust Screen Resolution" under "Appearance and Personalization." Click the drop-down arrow next to "Multiple Displays" in the window that opens. Select "Show Desktop Only On 2." Windows will disable the Mini 10 display and use the external monitor as the primary screen Read more: How to Run an External Monitor on a Dell Inspiron Mini 9 ' eHow.com http://www.ehow.com/how_6821296_run-dell-inspiron-mini-9.html#ixzz1hFvetaud
Nov 25, 2011 | Dell Inspiron Mini 10 Notebook
I can't get it to display anything but large icons and 800x640 display. It is way too large displaying anything.I have tried looking for a newer driver to no avail foe the multi media display.
  • Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window2_bing.gif open, click on Personalize, next click on Display Settings. You can adjust the brightness by doing the following: On the "resolution scale" adjust from (Low>High) you can do this until you are satisfied with the view. In the ("Colors drop box"), select the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance settings), select the ("List All Modes") button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection, and changes. "Restart the computer, to finalize the application." "Did this solution help?"
    Feedback: "Helpful Ratings" appreciated! thank paul7of9
Feb 05, 2010 | Toshiba Satellite 2775XDVD Notebook
Pink mark appear on screen and stays no matter what i am doing?
Unfortunately your screen is going bad. If it is under warranty have it replaced immediately. It will get nothing but worse. There are no viruses or setting in Windows that would cause such a problem. You may be able to minimize the distraction by right clicking on your desktop and going to settings and adjusting brightness, contrast, color, etc.
Apr 14, 2009 | Computers & Internet
Visulizations will not activate
Windows Vista has a unique feature like if u open something say a game & if ur display driver stops responding, it automatically restarts the Display driver & puts u back to desktop.
So might be, whenever u start ur Viz., the display driver would not be supporting it and so it gets u back to desktop.
for that i'll ask u to check whether u can see visulizations in ur Windows Media Player or not. if yes, try to reset ur display driver by uninstalling it & reinstalling it
thanks
Apr 12, 2009 | Computers & Internet
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Window xp display
This should be your graphics card driver is not it. The original installation of hardware drivers may be better.
If that is not what system you set up the software in question. Can be re-systems.
http://www.notebooks-driver.com
Nov 03, 2008 | Computers & Internet
Acer Aspire 5002WLMi Notebook Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
