Question about Texas Instruments TI-86 Calculator
Nmcdf and invnm
I'm borrowing my friends TI-86 because I lost mine a while back. I'm using it in my Statistics class right now. I need to use nmcdf and invnm but I can't find it on here. I think it might have been deleted. How do I get it back on here?
  • Anonymous Mar 03, 2009
    you need to download something for your calculator??
You need to download the Stats app for the Ti-86
Posted on Nov 04, 2008
I'm in a statistics class and need to find the area under a standard normal cube. I have a TI-81. How do i find that specific function?
Hey there,
You are looking for the cube root function which can be found under the MATH menu selection. the answer you get will simply need to be squared and you have your answer
Oct 03, 2013 | Texas Instruments TI-81 Calculator
I want to do a chi-square test on the TI-85
The chi-square test is used for a lot more than just contingency tables.
I found one program for the TI-86 (which is basically the same machine as the TI-85, only with more memory) which claims to do the chi-square goodness of fit test.
You might also want to browse through this archive.
Nov 29, 2012 | Texas Instruments TI-85 Calculator
I stop using my TI-86 for a few months and know
I hadn't used mine in years and had the same problem. Essentially you just need to give it a workout to get all the pixels working properly again and then it'll be just fine. I adjusted the contrast between full dark and nothing multiple times and turned the calculator on and off after each cycle and now it works like new.
Jul 06, 2010 | Texas Instruments TI-86 Calculator
Converting between Decimal Form and Degrees, Minutes, Seconds
Enter the angle in degrees-minutes-seconds using the single-tick (') for all three parts. Do NOT use the degree and second symbols. In my TI-86 manual, it's on page 285.
Jan 15, 2010 | Texas Instruments TI-86 Calculator
I'm an older student.....in my 50's. I am taking classes to complete my bachelor's degree in nursing, something I should have done 30 years ago. Better late than never, right? Anyway, I found my son's TI...
Hi Anne,
here are some tips to use your TI 83 calculator. Patiently follows this:
  1. Press ENTER to find out the answer to an expression.
  2. Press 2ND before pressing a button to use the function in yellow above the button.
  3. Press ALPHA to enter in letters.
  4. Press 2ND before pressing Alpha to turn on Alpha lock, which will automatically use the alpha mode until you press a directional key or ALPHA again.
  5. Press 2ND and then hold up or down to adjust the screen contrast accordingly.
Advanced Instructions
  1. Press MODE to go to a menu that allows to change graphing modes, degree modes, and notation modes among other things.
  2. Enter in a number then press STO> then enter in a letter and hit enter to store values in variables.
  3. Press Y= and enter in a function and then press GRAPH to view it. If you are having trouble viewing it, press WINDOW and adjust the graph's window.
Thanks,
Cherile
Aug 30, 2009 | Texas Instruments TI-83 Plus Calculator
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
Apr 23, 2009 | Texas Instruments TI-86 Calculator
IT-86 Both batteries removed, now dead
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
ftp://ftp.ti.com/pub/graph-ti/calc-apps/86/.
Hope it helps
Jan 18, 2009 | Texas Instruments TI-86 Calculator
Difficulty changing to the Statistics mode
Download the small instruction book from TI web site, keystrokes and examples at pages 10/11
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18
Mar 22, 2008 | Texas Instruments TI-30XA Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
136 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
