Question about RCA TruFlat 27F520T 27" TV
RCA tru flat 27 tv problem
Had a visible white vertical line at least 5 inches on top of the screen.
How will i eliminate or take it this out and clear the scrreen. help!! thank you.
  • nesty a Oct 14, 2008
    Thank you, u r a big help...
    Champion:
  • 252 Answers
The capacitor of vertical section is problem of your tv,so replace the capacitor value 100/50volts in or else all capacitors in vertical section.
Posted on Oct 14, 2008
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Hello
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
RCA CRT TV thin white horizontal lines
Look for bad capacitors in the vertical deflection amp, and in the pin amp sections. This is common on most of these types of TV sets.
The caps tend to go high in ESR with age. It is best to use an ESR meter to find the bad caps. It will be a lot faster than workign out waveforms with a scope.
Wikipedia explanation about capacitor ESR:
http://en.wikipedia.org/wiki/Equivalent_series_resistance
Jerry G.
Apr 23, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Truflat 27 inch rca
vertical capacitors beside of vertical ic no other problem the capacitors only
Aug 15, 2007 | RCA TruFlat 27F520T 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
RCA TruFlat  27F520T 27" TV Logo
164 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
