Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
2 router wireless
I had 1 router wireless and ready for working, then i need to add 1 more router wireless. how can i ?
pelase need all of your help ?
  • samedy sen
    samedy sen Oct 15, 2008
    yes, i got it but can i use it as same channel?
  • samedy sen
    samedy sen Oct 17, 2008
    other way if i conected internet by wireless into my laptop then i really want to share to other desktop PC, so how can I ?
    In this case someone told me about this but still not yet to test it, then they tell me nothing more
  • D-Link Master
  • 6,487 Answers
Yes, you can connect the second router to your exitsing router , you just need to connect the a cable from port 4 of the main router to the internet/wan port of the second router , then after that you can already use now the 2 wireless router at the same time. Also don't forget to turn off both routers after you're done in connecting them together so they will be synch...
Hope that helps...........
Posted on Oct 14, 2008
  • Mark Gil
    Mark Gil Oct 15, 2008
    Better if you use different channel so they wont interfer with one another..
    Don't forget to rate the solution FIXYA thank you....
Can I use one wireless router to connect to my primary wireless router?
You wouldn't use a wireless router for the second device -- you would use a wireless bridge device. Most Wireless Access Points can be configured to be wireless bridge devices or you may be able to find a dedicated wireless bridge. Unfortunately, these devices usually have just one Ethernet port. That will mean that you'll need to buy an Ethernet switch in addition to the device that you're going to be using as a wireless bridge. This will add to your cost and make it so there is no real cost savings by using the Wireless Bridge + Ethernet switch combination.
If you can find a wireless bridge unit that has more than one Ethernet port, then you may be in business.
Using a second wireless router will not work unless the device has the ability to be configured to be a wireless bridge. Such routers are usually more expensive than your typical router, but you might get lucky and find one at a good price.
Good Luck
Feb 09, 2012 | Linksys Computers & Internet
I need my WEP key code for my wireless router DSL - 2640R Broadland Wireless G ADSL2+ Router. I need WEP key...
So access the computer that the router is installed on. Open the program that managed the network ( I have seen these both as a program installed on the computer and as an Internet accessed destination). Select add device, once you have done that the key that you need should pop up. Just put that in your laptop and you should be ready to surf the net. If this helped please rate Thanks Robert
Jul 02, 2011 | Computers & Internet
We forgot our password to the router and we need to take the password off how would I do that?
Hi janiemae97,
This is how to reset your Belkin Wireless Router:
1.) Press and hold the 'Reset' butto for at least 10 seconds (It's located at the back righ beside power adapter port) then release it.
2.) The lights on the Router will momentarily flash.
3.) The 'Power/Ready' light will begin to blink.
4.) When the 'Power/Ready' light becomes solid again, the restore is complete.
Additionally, you can download the manual of your router HERE.
Hope this helps. Thanks
Feb 22, 2011 | Belkin (F5D8231-4) Wireless Router...
My wireless picks up my network but wont connect. It doesnt even ask for the pass key, which it does for other neighbour networks. I have just wiped my computer.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 28, 2009 | ASUS Computers & Internet
How to connect to laptop
Does your laptop come with a wireless feature? If not, you will have to add a wireless NIC. If you are not sure, you can go to Staples and ask the business machines person for a wireless NIC for your (fill in the blank that describes your laptop). He or she will tell you "Sure, here it is" or "your laptop is wireless ready! Here is how to turn it on."
XP and Vista will find the router easily and quickly. Run the wizard.
If yo need more help, let me know.
a
Sep 26, 2009 | NetGear WGR614 Wireless Router
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
Prolem with xbox
well if it IS working, you wouldn't be here would you? XD
anyways go to the wireless settings and manually add your SSID and WEP/WPA if applicable. If this doesn't work, get back to me.
Jul 31, 2008 | Microsoft Xbox 360 Console
Have router and want to add my 3in1 printer to my laptop,
You will have to add a print server to your printer. The best one for your router and printer would be the D-Link RangeBooster G™ Multifunction Print Server (DPR-1260)
Jan 10, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
