My YP-U3 doesn't show any files when not connected to pc.
One day after i transferred songs from my pc, I turned my mp3 on and when i looked for the files it only shown "No Files!" I checked if it had viruses and it had the Trojan disabler. i brought it to our technician for him to fix it. When I got it back he told me that it was all good. I checked the files and still there was nothing in it.I remembered that they reformatted it. After he had also fixed our pc from all the viruses. After installing the software, I tried transferring songs. I discovered that in the list, all the songs from my play list was still there.I tried playing it and it did play. The problem is that why is it when the mp3 is not connected to the pc it shows "No Files!"? Can you help me? Thank you :)
The Samsung YP-U3 is an MP3 player that comes in various colors. This device has a built-in USB plug, so it's not necessary to have a cable to transfer songs from your computer. To transfer songs to your device, you will need to use a PC. If you don't have the Samsung Media Center installation disc, you can download the software from the Samsung website.
Instructions
Install the Samsung Media Center if you have not done so. This is the software used to transfer songs to the YU-P3. The installation disc comes with the device. Simply insert it and follow the on-screen prompts.
Insect the bottom end of your device. You'll see a hidden USB plug on the end. Push it outward to extend it. Plug the device into your computer's USB port. This is usually on the front of the tower. The Samsung Media Center will automatically start after a few seconds.
Locate the file you want to transfer to the device. The Media Center's screen will display the MP3 (and other audio) files currently on your computer. When you find a file you want to add, click on it.
Click on the "Right Arrow" button. This transfers the song to the device. Repeat to transfer more songs, if desired.
Right click on the green USB icon on the right-side of your taskbar. Select "Safely Remove." Unplug your Samsung YP-U3 when prompted.
Hi I understand your concern. Let be more specific about this issue. If the songs what you have in your MP3 player is DRM protected, it can't be transferred moreover it won't work. Cause of DRM conflicts.... But you can transfer the non-protected songs into your computer. All you have to do is
Connect your device into your computer. Go to My Computer. Find the device, which is detected there. Right click and Explore it. Where you can find the folder which is corresponding to your musics. Explore it and transfer into your local HDD.
Kindly revert if any issues in that. I'm happy to help you..
**Drag and Drop** Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player. --**Windows Media Player**-- If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Press and hold the button while plugging the other end of the USB cable into the YP-Z5.
When the display shows USB Connected, release the button.
The device is now in USB mode.
When through, you must safely remove the USB device.
Note: To safely remove the USB device, right click the USB icon ( ) in the bottom right of your screen, and then click Safely Remove Hardware.
Upon disconnecting the device, it will return to MTP Mode.
Upgrade the firmware: http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
Then use Windows Media Player to transfer the songs.
