Paper stuck in the printer
I have a selphy cp740. As I was printing the paper started through and printer stopped with the paper hanging out the back of the printer. The message said replace ink cartridge. How do I release the paper. Just pulling on it does not work
  • xblackxskies Apr 17, 2009
    i had the same problem...the paper stopped and the screen said it need new ink. I had to pull the paper really hard to get it out. but my ink cartridge wont come out. so i dunno.
I had the same problem. I just pulled on the paper. I had to pull HARD and then it came out. When it was out I turned the power off on the printer and then back on, told the computer to carry on printing and it started working again. But you are right, the paper was really jammed in there, hard.
Posted on Nov 05, 2008
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
Colour lighter than previouse copies
Replace the ink-cartridges, to see if that fixes the problem.
Check the printer setup to see if it is in "draft" mode or "normal" mode.
Feb 24, 2015 | Canon SELPHY CP740 InkJet Photo Printer
STUCK CARTRIDGE
What printer? Fairly critical detail no?
Apr 02, 2017 | Canon SELPHY CP740 InkJet Photo Printer
My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. Printers has a good connection to PC, start to print but after the first paper pass the...
I've just had this same problem with my Sephy 740. Nothing helped until I disassembled the printer and realizing the small gear wheel (not visualized) at position in the red circle had loosened. Remounting the gear wheel on the shaft with a tiny drop of Blue Loctite and letting dry three hours, reassembling the printer and turning it on fixed the problem.
Aug 06, 2011 | Canon SELPHY CP740 InkJet Photo Printer
I want cd drive of my printer canon cp740..thanks
here is the link download your driver http://software.canon-europe.com/software/0026860.asp?model= http://canon.driversdown.com/search.asp http://driverscollection.com/?H=SELPHY%20CP740&By=Canon
May 14, 2011 | Canon SELPHY CP740 InkJet Photo Printer
Printer says "error on paper tray". The paper is
Are you getting a specific error message or error code?
Jan 03, 2011 | Canon SELPHY CP740 InkJet Photo Printer
My company has an Selphy CP740. The printer will
bring it in service centre, possible beside it dusty roller of the seizure of the paper
Dec 17, 2009 | Canon SELPHY CP750 Printer
Paper stuck in the printer because of dead camera battery
Been there before. There is no easy way to do this however you can call canon and there is a reset switch pattern that will rest the memory in the machine and run a self test at start up this may help
Nov 06, 2009 | Canon Selphy CP400 Thermal Photo Printer
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Jul 08, 2009 | Canon SELPHY CP740 InkJet Photo Printer
324 people viewed this question
jasbo
jasbo
