Question about Nokia 6600
How do I remove the write protection of my memory card Category: Question about SanDisk Memory Stick Pro Duo 512MB (SDMSPD-512) Posted by: 3-Apr I cannot copy data to my 512 memeory card as it is giving a meesage that it is write protected
  • 51 Answers
Hi
sir the write protection is not in your memory card. it is in you USB that you are using if you change the USB for example if you are using a 2.1 USB then you use 2.2 USB it will 100 % works. your USB is not able to read you USB
OR
there is a another way too try to copy some of your memory data to your computer may be 20 MB. then took any picture from your computer and drop it to your memory card if it accept then you may prceed.
thanks
your friend from fixya!
Posted on Oct 26, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I put the chip in the SanDisk to down load my music from ITunes and nothing happens i want to add my music to my smart phone please help
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on
the lower right hand side of the picture a slot that says "write protect", move that tab towards the pins to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
Sep 16, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
My usb memory stick is write protected,how do i remove that?
The adapter has a tiny switch on the side opposite the notch near the pins.
The switch needs to be towards the pins, not away from them.
Apr 06, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
How do i download from a san disk memory stick pro duo - 512 MB? the stick itself is way too narrow and short. help?
Aluratek AUCR200 Card Reader
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 14, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
I put a sandisk pro duo memory card into my camera but it says it cannot format because the memory stick is protected; how do i fix this problem so i can use it with my camera?
There is a small latch on the left side of the memory disk jacket where you will find Lock written, If you pull it to the unlock position then the write protection on the card will be removed. Please do that and use the card.
Dec 06, 2009 | SanDisk 2GB microSD Memory Card
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Cannot access and Format SanDisk 512MB memory Stick PRO Duo
Hi sir
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 26, 2009 | SanDisk Memory Media
Cant format
you can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
May 28, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Nokia 6600 Logo
109 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
