My SImpletech 1tb external harddrive won't turn on. it would flash blue 1 time and not read it on my computer.
    Genius:
  • 1,252 Answers
Check the power adapter of the drive, also check the drive on some different usb port
Posted on Oct 14, 2008
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I think everything got deleted off of my simpletech harddrive.. how can i know for sure?? what can i do?? the red light turns on but all my movies and music are gone
double click on MY Computer, then double click on the drive letter for ur Ext H Drive and see what comes up. or right click once highlighted w/mouse pointer and select properties
May 03, 2010 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Simpletech external harddrive, blue flashing light with a constant beeping
Your drive is not getting enough power. try a different usb cable and a different usb port on the computer
Sep 26, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
500g simpletech extrenal harddrive will not turn on
Sounds like a drive failure. If it under warranty then its time to trade it in.
Jul 29, 2009 | Western Digital 500GB My Book Pro-External...
Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Jan 22, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer wont recognize external drive
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Sep 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
