Question about Watches
UNITAS EXTRA VINTAGE WATCH. NEED INFO RE WATCH VALUATION
UNITAS EXTRA. LADIES WATCH.
17 RUBIES MARKED ON THE MOVEMENT WITH THE NUMBER 60 UNDERNEATH. WHAT IS THE ACTUAL MOVEMENT?
THE REVERSE CASING HAS THE UNITAS COAT OF ARMS WITH THE NUMBERS 47219 STAMPED ON THE ALUMINIUM BACKING.
IT HAS A LEATHER STRAP.
IS THIS WATCH GOLD?
IS THIS WATCH VALUABLE?
IS THIS WATCH SOMETHING A COLLECTOR WOULD WANT?
CVAN YOU POINT ME IN THE RIGHT DIRECTION FOR MORE INFORMATION IF YOU DON'T KNOW THE ANSWERS?
KIND REGARDS,
CHRIS.
SOURCE: History & battery number
377 ETA
Posted on Sep 18, 2009
  • 2501 Answers
SOURCE: need to know date of movado watch
Go to Modavo.com and on the opening page you will see "service" in the menu.
Select this and then "other questions................" and ask them.
Posted on Jan 31, 2010
  • 2501 Answers
SOURCE: Bulova 14k Solid Gold woman's watch. Swiss 17
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
Posted on Mar 17, 2010
  • 172 Answers
SOURCE: I went to put a
A watch with no movement in it is probably a salesman's sample or display model. These are often distributed to stores as part of a larger display. In addition to missing a movement, you should also check to see whether the hands have been glued in place. This is also often done because, without a movement, the hands would just flop around instead of staying in an attractive position.
Watch movements come in a variety of standard sizes and shapes. However, a standard ladies watch movement (made by many manufacturers) would probably fit your watch case. This size movement is today used in much larger watches, too; the movement is simply anchored by an appropriate spacer.
A jeweler advertising watch repair should be able to offer you a price on this job. If the hands have been glued to the dial, it may not be worth "upgrading" the watch because of the additional expense and potential damage to the watch face from getting the hands freed up.
If you're ambitious and want to try it yourself, movements can be found online at a variety of watch supply houses like Otto Frei. You can also buy a cheap new or used watch at a flea market or thrift store and use the movement from that. You might be able to re-purpose the spacer in that watch, too, by trimming it to fit your watch case. The major stumbling point here is that watch stems--i.e., the stem on which the setting crown is located--are usually custom-cut in length to match a specific case, and the one you select may be too long or too short for your case. A watch repair place should be able to replace the stem and crown for you, if you need that service. Trimming an overly-long stem is a very simple and cheap procedure; replacing the stem requires a new stem, which will add to the cost of the repair.
Posted on May 09, 2011
rockmeister
  • 2047 Answers
SOURCE: I need a valuation on
Hello there, the serial number on a Movado watch is usually unique to each watch and therefore a watch cannot be identified by that. Here is a picture of all the gold ladies Movado watches which are presently available. I have numbered them 1 - 8 accordingly.
1 and 2 are both tagged the Amorosa and are valued at $895 and $1395 respectively.
3 and 4 are both tagged the Concerto and are valued at $2495 and $1495 respectively.
5 and 6 are both tagged the Bellamoda and are valued at $1495 and $1095 respectively.
7 is the Harmony and is valued at $895
8 is the Rondiro and is valued at $1495
If your watch is not on the list above then you might want to send it to the nearest Movado authorised dealer to confirm if it is original or a knock off.
Hope this support has been helpful?
Thank you for visiting FixYa
Posted on Sep 11, 2011
Where to look up number on my Bulova ladies gold wrist watch vintage
put make model and any numbers into google.
or put more info on here.
or if you are asking were is the number on the watch you will have to take the back off it and see if there is a number in there.
Nov 29, 2016 | Bulova Watches
Came across a vintage minerva stop watch can you help price it.
ebay lists 7 search results between £30 - £190 I guess it depends on the exact age and model and providence of the particular watch. Only a valuation by someone who is familiar with this market would be able to tell you.
(search on vintage Minerva stopwatch)
12.February.2015
Feb 12, 2015 | Vintage Watches
I need a valuation on a ladies gold movado watch. Serial number A63165
Sep 10, 2011 | Watches
I want to know the value of my ornet antimagnetic pocket watch i think its from hong kong and this watch is old the case of this watch have a man fishing somewere in the river with lots of the treeson his...
It's rarely possible to give any kind of definitive valuation without seeing a watch (pocket or wrist) in person, but it sounds like you have an inexpensive pocket watch that was probably made in the 1960s, less likely made in the 1970s or 1950s. The use of the term "antimagnetic" on the watch, as opposed to "17 jewels," suggests that the watch is powered by a 1-3 jewel pin lever movement, rather than a more expensive movement. These movements can keep quite good time, but they are not valued by watch collectors unless the rest of the watch is of compelling interest.
In terms of value, your pocket watch has more value as a piece of jewelry than as a vintage timepiece. Most watch collectors would not be particularly interested in your watch. In the United States, I've seen similar watches, in running condition, sell for $5-10 at vintage watch fairs. Around where I live (the Northeast), as a piece of jewelry, your watch may be worth twice that but not more. I cannot speak to pricing in other parts of the country or internationally.
Jun 12, 2011 | Watches
Need appraisal on my grandmothers old bulova watch, serial # 1518119. It has links as its bracelet and is attached to the watch on its side with clips
Without more information, such as a picture of the watch or more information about the case, it is difficult to provide a value for this item. In general, vintage fancy ladies watches (the kind that are approximately the diameter of a U.S. nickel or smaller) are not very collectible. As recently as a few years ago, these were bought and sold in bulk for only a few dollars each. In nice cosmetic condition and running properly, a Bulova ladies fancy dress watch in a steel or gold-plated case might retail for between $15-50 at an antique mall. They might sell for somewhat more at a jewelry store that stands behind the accuracy of the movement, but because the inventory of these watches is so large and demand is fairly small, prices for these watches remain much more modest than similar age men's mechanical wristwatches.
Some valuation exceptions do apply. Certain brands of watches, such as Rolex, IWC, Blancpain, and other premium brands, are worth much more than common brands like Bulova. Ladies watches with sweep second hands, as opposed to fancy watches that just have hour and minute hands, are more desirable and are also worth somewhat more than average. Also, watches in solid gold, platinum, or silver cases--or watches with diamond chips or ornate cases--are also worth at least their "melt value" as scrap metal or have an independent value as fine jewelry. All precious metal cases must be labeled; if they are not labeled on the outside of the back cover, they should have be marked on the inside of the back cover (you'll need to carefully take the movement out of its form-fitted case to see this). Be aware that "14k RGP" or "rolled gold plate" on the case means it is not solid gold. Similarly, cases that are "warranted" for 10, 15, 20, or even 30 years are also gold-plate, not solid gold.
Today, with the increase in gold prices, many people have been buying these watches to melt down the gold-plated or gold cases for their gold value, throwing out the watch movements and watch bands. This may have a long-term impact of raising the value of these watches in the long term, as this is decreasing the supply of available watches of this type (it's also frustrating to watch collectors to see the watch movements discarded, as these are valuable sources of replacement parts that are no longer made). However, tens of thousands (more likely hundreds of thousands) of these watches exist in the United States alone, so there is little likelihood that these will become scarce in the immediate future.
May 09, 2011 | Bulova Watches
Trying to date vintage Bulova ladies 17 jewel watch Swiss movement. The code stamped on the back of the watch is W80701
The best people to consult is the manufacturer.
Go to http://www.bulova.com/contact/contact.aspx (click on this link) and you will see a number of contact address.
Contact them and I would expect them to be able to dig out the information you require.
Mar 08, 2011 | Bulova Watches
Hello iam looking for the serial numbers for a two-tone omega ladies watch. nubers start with 5310 but can not make out rest.
mcdevito75 here, Best Bet, the number on the movement itself is the number that you should go by, this number gives all the info about the watch, other than that, you should be able to find a strong magnifiying glass at any Dollar store to help with reading that serial number, or, see any small watch repair shop in your area.
Jul 02, 2010 | Watches
Fake or not
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Oct 13, 2007 | Timex E Tide Temperature Compass Watch...
Watches Logo
225 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
