Question about Brother MFC 420CN All-In-One InkJet Printer
The printer simply says, "Unable to print. See troubleshooting and Routine Maintenance guide chapter in User's manuel." Thanks.
I recently posted that I had a print unable 51 error on my Brother MFC5460 CN All in one.I've read many tips and I was willing to try them all before taking it apart. I'm not sure if the solution I used to solve my problem is like someone else's here but I saw a white piece of plastic behind the print carriage that was still attached but stuck out to the left side when the carriage was in the right side of printer. It wasn't unhooked or looked like what I thought the encoder looked like, but I slid it over to the right side of the print carriage. I was able to move the carriage right to left and back to normal position before but moving that piece of plastic solved the printer error. I cleaned the cartridges,inside where the cartridges go into printer as well as the maintanence tips. Thanks to all the people that take time to post tip solutions that worked for them and ideas thought of to try.
Posted on Jan 25, 2012
    Sergeant:
  • 352 Answers
Hi Bang, give this a shot,
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 14, 2008
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
