Question about Intel D865GBF Motherboard
Thanks I can't say even Thnaks Thanks Marked i'll contact with u if it doesn't buther u.
  • 6,487 Answers
No problem, contact me if you still have any problem
Don't forget to rate soultion FIXYA thank you....
Posted on Oct 14, 2008
I need esonic awrdacpi audio driver
Hi'' i sagest for you to contact me my no.+639282825180 and i'll provide you 100% all driver installer . or contact and thanks for using fixya.com
Jun 18, 2012 | Intel D915GAG Socket 775 Motherboard -...
I have asus p5sd2-vm motherboard when i start my pc it show fatal error system halted.when i restart pc it start normally pls solve my problem
I agree with Mike, check the RAM first by making sure the sticks are seated correctly with the PC off, then start it up. There is less chance if you have more than one RAM stick that all will be bad so try swapping them or using one per system restart. If this doesn't work then try newer sticks. Even with bad RAM you should be able to see BIOS during boot. If it still happens then there's a problem on the motherboard itself or the CPU (although on some systems you'll see nothing on the screen if CPU is bad) .
Aug 13, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wall paper for windows 7 starter
Hello there,
Its one annoying limitation of Win7 Starter edition.
Download
Once you install Starter Background Changer on your Windows 7 Starter system, you'll find a new Personalize command added to the desktop context menu - the one that pops up when you right click on the screen. Select it, and you'll be able to customize your wallpaper straight away
1. Download the file on the link.
2. If the download doesn't start automatically, check again.
3. Install the file.
4. Look for the Personalize command added.
5. Change your background.
Hopefully this helps.
Thank you for posting..
Jul 14, 2011 | Computers & Internet
Intel dh55tc how many RAM slots is there
Dear p_raveen8376, there are 4 RAM slots on Intel DH55TC board. But you have to use the slots systematically. You'll have to use those in pairs. Four slots are marked by separate colors (i.e. 2 in Blue & 2 in Ash Color) and demarketed as DIMM_0 & DIMM_1. First, you'll have to use pairs of DIMM_0 with same RAM (same frequency like 800 MHz or 1333 MHz or so on), preferably same make. Thereafter, if you like to upgrade, you can use rest pairs of slots with different RAM i.e. other frequency, or other make.
Feb 21, 2011 | Intel DH55TC Motherboard
Hi I have a satellite l30-134 and I am unable to boot the laptop without the request for a bios password, I have tried everything I know can you help with some suggestions please, I can not even boot off...
Power on password. You will not be able to boot from anything until you disable this, even removing the CMOS battery wil not work.
Options are:
1.) Email Toshiba and get them to send you an unlock code
2.) Try visiting Dogberts site of reverese engineersing for his brute force pass cracker
If you feel confident, on this laptop there is a way of removing the password, I take no responsibility iof it goes wrong.
Remove the Ram module cover
Under the ram modules there are two contacts marked C88 and an X near them
Touch the two contacts with a screwdriver and power up the laptop, the bios screen should now go and you can access the laptop.
Feb 10, 2011 | Toshiba Satellite L30, L35 Series Laptop...
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Mother board doesn's recognized sound device, c-
I guess there is problem with drivers my be they are not properly installed.. For this Go to Control Panel ---> System ---> Hardware ---> Device Manager if you have any device marked with a question mark or yellow admiration. See also Device Sound, video and games, to see if the driver is installed.
if you got a Software CD with your system then it should have the
Audio Drivers. Just Reinstall it.
I hope it will help.
Thanks
Sep 24, 2009 | Matsonic MS9158EP (DSMTSMS9158EP)...
I want to upgrade the cpu on mb SP# 252608-001
please let me know the make and model number of the mother bord
thnaks
Jan 24, 2009 | Compaq (252608-001) Motherboard
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Graphics card problem
if there is not slot for AGP then you can not use your new graphics card. Maybe you can replace card with PCI type. im sure your board supports pci slots
May 11, 2008 | ASUS P5PE-VM Motherboard
Intel D865GBF Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
