Question about Whirlpool Duet GHW9150P Front Load Washer
Water overflowing from dispenser, no error codes
We have a Whirlpool Duet front load. Today water overflowed from the dispenser. There are no error codes showing. Flushed and water drains slowly into machine now. Any ideas.
  • 958 Answers
Check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
  • 1 more comment
  • lina_merchan Nov 13, 2010
    I solved my problem. I tried the empty load with hot water and it didn´t work. I removed the soap dispenser and I didn´t see anything. I was determined not to pay someone to fix it. I prayed to god to help me. I removed the rubber seal by pulling from the lower part. I traced the tube from te soap dispenser, and then from the inside I checked to see if there was anything. I FOUND some underwear stuck in the hole. Now I only need another person, my husband is traveling, to help me put the rubber seal because you need 4 hands to stretch it.
  • Graglor Feb 05, 2012
    Unreal. Same problem, same fix!!! A 14 inch long sock in a four inch hose. How the hell it got in there I'll never know!!!! The door seal is easier to put on it you use pliers to unhook the little spring, install the seal, then hook the spring back on. Thanx for the help!!!!!!
  • bobe_98
    bobe_98 Dec 26, 2012
    i hi had the same problem and what i found was pieces of thread from towles in there
    New Friend:
Same problem. Removed the top, and the front-top panel, then the dispenser assembly. Remove a sock stuck between the dispenser hose and the drum.
Posted on Mar 13, 2013
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
I have a Whirlpool duet and water is over flowing and coming out the soap drawer. I have tried flushing out the opening with a hose and it still over flows. Any suggestions?
Hi, W/D here.
Remove the dispenser tray. Clean the overflow caps on the underside of the dispenser, and clean the tubes from the dispenser to the hose to the drum. In the more serious clogs, you may need to clean the hose to the drum.
Best regards, --W/D--
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an f27 error on my washing machine. Can you explain to me where the pressure switch is? I have the front, back, and top off of the machine.
Error code f27 is OVERFLOW CONDITION.----------
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.----------
Check:----------
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
----------- This should help.Thank you.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
servicing.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front end loading washing machine when the water goes into the dispenser it doesn't go down the hose and comes out and leaks onto the floor?
most of the time when this happens the hose going into the tub is blocked with soap so the dispenser overflows have a close look and clear the obstruction also check for split or loose hose hope this helps you
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is showing a flashing f09
Hello Sir, If the Washer is turning on itself then it is a CU Problem. It must be tripped or not functioning properly.
And about the F09 error. This error comes when the washer has a water overflow. This can be removed by tilting the Machine forward by making a point opened so that the excess water flows out. This overflow is caused when the water is blocked by any other object. This overflow is surely corroding the CU and making the machine to turn on by itself.
Kindly call a technician from Whirlpool to get the internal parts checked.
Thank you Sir, Have a nice day.
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
Check
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer-error code e-1?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softener dispenser
thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, not an issue at all
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
986 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
