Question about Haier Dishwashers
I have a HDW 201 WH dishwasher. the three lights on the end are flashing and beeping seems to be stuck half way through the cycle. checked water, filters etc. is there an easy fix?
jsrock516
  • 5911 Answers
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Posted on Jul 10, 2007
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Posted on Oct 29, 2008
SOURCE: We have a Blomberg dishwasher. We came to a
I am curious what the repair guy found. We have the same problem.
Posted on Feb 08, 2010
Why doesn't it work?
please provide model number of the Dishwasher and the exact keys where the three lights glow.
Perhaps a photo without flash will help
Mar 29, 2016 | Samsung Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Whirlpool dishwasher.... Continuous flashing light an a beeping noise half way through cycle then dishwasher stops!! Help! X
Check your sink drain to see if you dishwasher is able to exhaust water out. The exhaust drain hose, or the drain is plugged. They get debrea from food being washed off the dishes.
Nov 19, 2012 | Dishwashers
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
MY GE Triton GSD5200 just stopped mid cycle...it is beeping and the normal cycle light is blinking. What is wrong?
I had the exact same problem. It was near the end of the cycle and it just stopped and then started beeping. I opened the door, and something seemed to pop. Looking at the mechanism, I'm thinking that the Jet Dry dispenser had gotten stuck somehow, and fiddling with the door loosened it. If it gets stuck again, I'll probably just remove it since I never use Jet Dry.
Jul 03, 2009 | GE 24 in. GSD5200 Built-in Dishwasher
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
49 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
