Question about Samsung Prostar 824 Keyset Telephone
Paging need to know what pairs are used for pageing and dry contact if any on a DCS
  • Bill Oswald
    Bill Oswald Oct 14, 2008
    Thanks for the help
  • 2,460 Answers
Pair 6 of an A1 trunk card is the MOH input.
There are 2 sets of dry contacts for paging. First, pair 8 is the speaker, then 9&10 and 11&12 form 2 sets of dry contacts in the NC NO skip COMMON sequence.
Carl
Posted on Oct 14, 2008
Spike lag
Ram Upgrade!! That is were to start. Also make sure you have some hard drive space and open up paging. Paging uses some of your empty hard drive space as Ram. I don't know what OS you have you can go to your system settings in the control panel. go to advanced tab and in the virtual memory you can adjust you allotted paging space. You might want to also consider lo lowering graphic details in the games you are playing.
Jun 21, 2013 | Sony VAIO Computers & Internet
Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
this is the link to help you.
http://www.britishtelephones.com/qfmenu.htm
this will help you for sure.
but a service technical at your place will be more better choice.
because if you make one wrong connection some of the function would not work properly.
rate the solution as fixya if it helps you in solving your problem.
Jul 01, 2008 | Lands Phones
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
Jan 10, 2013 | Avaya Partner ACS 308EC (108463001)...
Hello, pleas I need service manual for Kodak DCS
HelloUnfortunately, the service manual for your Kodak DCS 14n is not available anywhere online. The manufacturers of this product did not make it available.
I would suggest you contact Kodak and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
Here is a direct link to Kodak's DCS 14n digital camera support page :
http://www.kodak.com/global/en/service/professional/..
To view the page just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
Jan 19, 2012 | Kodak DCS 14n Digital Camera
Can't remember, what 2 terminals I punch down for paging? Was thinking is was the violet / blue pair, but thats not it. HELP! Chuck
it depends on the system type, on an MICS the external page is on the yellow/blue pair of the second connector (right above the MOH pair).
on a CICS, it the violet/brown of the second connector (right below the MOH pair).
Sep 24, 2009 | NorStar Meridian M7310 Phone
Overhead paging
How do you dial paging? Pressing a button or dialing a code?
THat phone can be on a few different systems, do you know what you have for a phone system?
May 28, 2009 | Lucent PARTNER18 Corded Phone
T5420 unable to transmit or receive. Please help!
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Paging file in a pc
This error is caused when Windows tries to create a paging file in the NTFS drive, but the account you're logging in under, doesn't have the security level to complete the task.
In other words, windows is trying to create something, but the account doesn't have enough security to do it.
There is a fix directly from Microsoft that will fix your problem:
http://support.microsoft.com/kb/315270
Oct 24, 2008 | Gateway Computers & Internet
158d system
The paging connects to one of the line ports on the system. Its needs to be specified in system programming which line you will be using. When you login to System programmiing (feature-0-0-left intercom--left intercom) you can go to Loudspeaker Paging Line #617, then select an unused (available) line. (feature-0-0) to save. Then go to the system and the port of the line you selected is where you will connect the signal leads to the paging horn. Then use Intercom *70 to page or program a paging button
Aug 25, 2008 | Lucent PARTNER18 Corded Phone
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Samsung Prostar 824 Keyset Telephone Logo
77 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
