Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Printshop Deluxe 20 and HP Photosmart C4180 printing problem
I'm about to pull my hair out. I've spent hours atempting to print greeting cards out. I'm using Printshop Deluxe Version 20 and attempting to print to my HP Photosmart C4180 printer.
Designing the card isn't a problem. When I go to print preview the design is off the page with a small portion of the image in the right hand corner of the paper.
How can I get the image/design centered and printing properly. I've scaled, changed paper size and nothing helps.
Thanks for your help.
  • ai-ling logan
    ai-ling logan May 11, 2010
    HP has driven me nuts too, but maybe my troubles can help you, but need some more info.
    First, have you had success with this same software and alternate printers? Or is the printer exibiting problems with any other programs?
    Second, are you trusting the preview window or have you actually gotten hard copy that is out of whack? I find that some of the previews are not entirely accurate.
5 Suggested Answers
SOURCE: need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Posted on Mar 07, 2009
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Posted on Mar 17, 2009
  • 6 Answers
SOURCE: printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Posted on Jun 27, 2009
  • 195 Answers
SOURCE: I use Windows 7 and the PrintShop Deluxe 22 will not work.
Microsoft's Windows 7 compatibility list shows this product as unknown at this time and recommends using the Vista compatible version. If you need to upgrade to the Vista compatible version there is a free update located at the link below.
Posted on May 31, 2010
I have an HP Photosmart C4180 all-in-one. I have never been able to get it to print. I have just spent several hours over two days with no luck! It prints but nothing shows on the paper. I have...
Remove the the cartridges.Just touch the print head in a soft tissue. Try make a line in tissue.If the line not come u should change the cartridges. becos print head getting dry.If this ink come out there error for printer.
If your cartridges is dry it clear a refilling technisian.May they having machine clear this problem.
ooooooooook dear,inform me
Jun 17, 2011 | HP Photosmart C4180 All-In-One InkJet...
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
I have an HP Photosmart C4180 all in one and would like to know how to print #10 and also wedding size envelopes. I have tried changing the orientation on the Properties tab and changing the envelope size...
Hello Friend,
When you want to print page # 10 please see below and for wedding card printer please select envelope size from printing prefrences menu.
Start>settings>controlepanel>printer>C4180>Properties>printing prefrenes.
Apr 03, 2010 | HP PhotoSmart C4180 All-in-One Color...
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
Need to print a half-fold card envelope with HP Photosmart C4480
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
I can't install printshop 20 for vista
i have printshop deluxe v20 won't install on new computer window 7
Dec 11, 2008 | Broderbund The Print Shop 20 Deluxe for PC
HP Photosmart C4180 won't print
you can get the newest vista software for your laptop from
Apr 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
55 people viewed this question
Ben Johnson
