Question about Video Game Consoles & Games
I have a laptop, and my internet connection is broadband from o2, simcard. How do i connect my wii console to the internet? I have tried with a lan adaptor to the laptop and it does not work
    Sergeant:
  • 306 Answers
Get a router. Hook up modem to router and then connect Wii to router. A router may be the good option to connect the wii console to the internet..http://www.acnt.com/showpages.asp?pid=11...
Posted on Oct 14, 2008
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
if this help you please rate me thank you sir.....
Jul 05, 2011 | Nintendo Wii Console
Setting up wii for netflix
Netflix Instant is available for streaming on your Wii gaming console by early spring 2010. If you have a Netflix subscription you can watch movies and episodes easily on your TV through your Wii console. This article will detail the important things you will need to make sure that you can watch Netflix from the Wii.
Difficulty:Easy Instructions Things You'll Need
  • Netflix subscription
  • Nintendo Wii gaming console
  • Broadband internet
    • 1 Check you Netflix subscription. The minimum subscription plan to watch Netflix instantly is the unlimited 1 DVD at a time plan or otherwise the $8.99 plan. This plan allows to watch movies instantly with unlimited monthly hours.
    • 2 Check internet bandwidth on your broadband connection. According to Netflix the minimum bandwidth requirement is 1.5Mbps. Netflix recommends for watching movies instantly a 3.0Mbps connection. Check with your internet service provider to confirm that these download speeds.
    • 3 A wired connection to your Wii console. An ethernet connection to your Wii console would be preferable. Unfortunately the Wii console does not have an ethernet port but a USB port. A USB LAN Adapter can be found at most computer supply merchants or online from Wii or Amazon.com. The ethernet connection is an ethernet wire from your home LAN router connected to your USB LAN adapter. The USB LAN adapter is then connected to the USB port on the Wii console. This connection will be how Netflix provides the movie streaming feed to the Wii.
    • 4 Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Read more: How to Setup Netflix for Wii ' eHow.com http://www.ehow.com/how_5893624_setup-netflix-wii.html#ixzz1OybxaAO2
if this help you please rate me sir thank you so much...
Jun 11, 2011 | Nintendo Video Game Consoles & Games
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
May 05, 2011 | Nintendo Wii Console
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
Mar 15, 2011 | Nintendo Wii Console
I plugged in my wii LAN adapter and tried to test it but didn't work?Wired Connection
Make sure you are using the Wii lan adapter made by nintendo
  1. Make sure you are using a "broadband" internet connection, such as high speed cable or DSL. Slower connection types, such as dial-up, may not work properly with the Wii console. If you are unsure what type of connection you have, please contact your Internet Service Provider (ISP) for more information
  2. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  3. Your access point (wired router, broadband modem*) may have certain firewall settings that are preventing a successful connection.
better u download repair guide
click here to download repair guide
Dec 16, 2010 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
Sep 13, 2010 | Nintendo Wii Console
Connection Comcast router to wii
Error Code: 52021 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Mar 13, 2009 | Nintendo Wii Console
Wii wired internet connection problems
if you have all of these
Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
  • A Wii LAN Adapter (where to buy)
  • An active broadband internet connection, such as DSL or Cable.
  • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
  • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
  • An ethernet cable.
then go here for more information
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
this information was found on nintendo's customer service website
I hope you find it useful
Dec 29, 2008 | Nintendo Wii Console
Connecting my wii to the internet
to connect your wii to the internet connect to the following link or read the following instructions
http://systemsetup.nintendo.com.au/Connecting_Online
to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
a computer connected to broadband internet
a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
your wii console to be nearby all of the above
If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
if you are using a wireless connection follow steps below.
Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
On the next screen, select 'wii settings'
In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
Select 'connection settings'
select an open connection indicated by 'none'
select the corresponding option, Wired or Wireless connection
Wired:
Wireless:
Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
the wii will search for an access point, select the access point you wish to connect to, and save the settings
The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
hope i helped!!
Sep 19, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
