Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Thanks First, Thanks alot for your solution. I did that but it doesn't work, and i'm sure i don't have any bad in my hard becuse i checked it by the HDDregenerator and i didn't see any think. if you have any thing else. plz.
  • 6,487 Answers
Try first to scan the ahrd drive using a good anti virus like Avast and a anti malware software like Malwarebytes , this tow are good in cleaning your computer for some harmful worm, virusess and malware that can also cause this problem..those tow software are free so you can just download thme and use on your system....
DOn't forget to rate the solution FIXYA thank you...
Posted on Oct 14, 2008
I forgot my email password and do not know how to
hello deer
can yours help me in arabic becus my english so not will or bad thxx alot
Jun 21, 2013 | Computers & Internet
Its not picking up good
well..make sure the belt is on correctly..make sure u empty dirt..carefully tryto see if it is clogged..maybe a hanger..carefully
Dec 10, 2012 | Bissell 3102-0 EasyVac Upright Vacuum
The hard drive don't running
Check connections. If that doesn't work, try putting it in a different computer. If that doesn't work it's probably broken.
Feb 11, 2012 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
E000602-0502
Don't really know, but probably the copier's hard drive is bad or going bad. You may be able to simply reload the firmware, but if that doesn't work, it may require replacement of the hard drive.
Call Canon, they should be able to help.
Oct 19, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Hi my dimension 3100, just after the boot the screen stay on the progression bar and no more! I just can read Dell DV051 Series Bios Revision A03 and in the lower corner the logo Intel Inside pentium...
are you saying you are stuck on the screen that says dell on it as soon as it turns on, and that f2 to enter bios does not work? if so, the issue can be related to a bad hard drive or bad motherboard. i have come across this issue alot, normally on desktops, and those are the 2 fixes that are usually the problem.
Jul 08, 2011 | Dell Latitude D600 Notebook
I have a SimpleTech 1TB hard drive and I have alot of important documents on it. Everytime I plug it in a message comes up saying that the "Usb device is not recognized" I hooked it in a couple...
Let's try to get it recognized. I Presume you are using Windows... Make sure that your drive is connected and turned on. Go to your Control Panel, Then " Add Hardware". Just follow the prompts from there. To make sure it's recognized, go to your Desktop. Press "Start " and right-click " My Computer ". Now go to the last entry " Properties " , Then " Hardware " then " Device Manager ". If it still doesn't show them, I'll suggest you check your cables. Hope this helps. If so, don't forget to rate the answer please.
Jul 08, 2011 | Computers & Internet
The headlights work but turn signals don't and hazards don't work either and brakelights still don't come on.
one bad bulb will be your problem. Doesn't matter which side. If one bulb is bad in the front or in the back, left or right, then you have the problem you are having. Check your fuses first. Little easier to change a fuse than a bulb.
Jun 06, 2011 | Ford F-150 Cars & Trucks
Tombraider underworld has started to run slow
Before you start any game, this is what I do:
1.)Hold down the Ctl button and push the Alt key and delete button.
2.)Once you have Task Manager running click the Processes tab.
3.)Right-click and choose End Task on any extra software programs you don't need, and make sure you save and quit any other programs which are open and you don't need.
4.)That usually frees up alot of memory from bloatware (extra software you never even knew ran in the background of the computer and that you don't need).
5.)If you don't know which to close down, try them out, for sure you need to keep open explorer.exe because that's your computer.
6.)If that doesn't improve it much, run a disk clean-up by going into My Computer, Right-Click on your hard drive which has the game installed on it (normally drive C) and click the Disk Cleanup button under the General tab.
7.)Finally also under that properties window you can go to the Tools tab and do a disk defragmentation.
8.)Restart once its done, but down forget to close all the bloatware again from Task Manager.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Computers & Internet
My 1992 GMC Yukon will not start. I will turn over but not start. Has a new barttery and cables. It is not the gas pump becuse I can smell gas from the carb.
You need to check to make sure it has spark. If not it may have a bad ignition module or coil, or problems inside the distrubutor. It may have a faulty temperature sensor for the ecm which can overfuel or underfuel it. You need a scanner to check that. You need to check fuel pressure. Just because you smell gas doesn't mean that the pump is woking correctly.
Apr 21, 2011 | 1992 GMC Yukon
My hard drive is clicking alot & I am getting alot of freeze ups/ super slow response time , white faded screens etc. Need to replace?
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no MOISTURE in the air lines then give the hard drive a firm tap on the side to free it up
test or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure the connections are securely seated and they are not bad/faulty and no dust built up I would simply replace them
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
defragment your hard drive will speed up your computer
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
don
Feb 14, 2011 | Samsung 500 GB 5400rpm SATA2 8 MB Notebook...
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
62 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
