Question about HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
I have Designjet 750c plus. the plotter shoes load error sometimes and sometimes shows me out of medi when meia is loaded. could you tell me how to fix it?
thanks
Bagi
U could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Posted on Oct 15, 2008
Hp 750c Designjet plotter system error 010030 00070b20
This is a problem with one of three
  • Trailing cable
  • main PCA
  • carriage assembly
Jul 09, 2012 | HP DesignJet 750c plus InkJet Printer
DesignJet 750c Plus System Error 040502
The bad news is that this seems to be a fatal error of the main board. The only time I have had a similar error is when the carrage motor shorted out and blew the main board. This probably did not happen in your case but something appears to have taken the board out. The main board is speculation, but I think I am correct, sorry, Dave
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media
Look under the plotter on the control panel side. You will see a sensor with two wires comming out. This sensor is dirty. You can try and blow it clean (often works) or remove it and clean with a small brush. It clips in and out but be careful and take note of the clips etc remove it without breaking any.
Feb 19, 2009 | HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
HP Design Jet 600 Plotter
The problem the 'alignment error' this causes is car desalignment, is need repair phisical.
May 29, 2008 | HP DesignJet 1050c plus InkJet Printer
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Jan 09, 2008 | HP DesignJet 450c InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
179 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
