Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Plasma 42" daewoo edtv black line down middle
Hi, I took my plasma 42" daewoo in for service. It had a vertical line right down the middle. I paid 60 and they said daewoo discontinued the part i need. They said it's the main panel (Picture tube for plasmas) part number is 485om06110 pdp. Do you think it's the panel? If so is there a universal part i could buy after market? Thanks!
    Problem Solver:
  • 6 Answers
Attempting the solder fix is a big undertaking, gaining access to the components is a MAJOR undertaking, and probably not worth your while.
If it is simply one line you might try the baseball Bat fix....
In reference to the "basebal Bat fix" it works on occasion by using percussive force to realign the ribbon cables.
DO NOT use a baseball bat, but use a rubber mallet and with the power off tap gently directly above and below the offending line.
Its worth doing this if yo cannot live with the line.
If you can live with it, leave well enough alone!
Posted on Aug 24, 2009
  • 24 Answers
There is a youtube video that documents the repair of similar symptoms in a Hyundai set
http://www.youtube.com/watch?v=9NPobj0_GSo
I haven't tried this kind of repair but given that plasma TVs usually run hot (especially the cheap ones w/o fans), I'd think this has a decent chance of working. Just use a nice temperature controlled soldering station (Weller/Ungar), keep the solder tip temp just high enough to melt the solder and most importantly - use a dab of solder so there is some flux to re-wet the solder joint. If you don't add any solder, the joint will just fail again.
Whatever you do, don't try to fix it like the youtuber with the baseball bat.
Posted on Dec 28, 2008
  • 30 Answers
It could be the panel but it could also be the ribbon cable that attaches to the display from the X module. It is a major job either way.
Posted on Oct 14, 2008
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
BLACK VERTICAL LINE ON RIGHT SIDE OF TV
I hope you are handy with tools!!!!!!! Just wanted to let everybody know that my plasma has the same problem but mine works fine for a minute and then it has the black line.. I took mine apart as suggested above.
I took regular wrtting paper used as a shim to make the contact
tighter, so far is working just fine.. I do not know if the paper is safe but I'm allways watching mine screen.
Please read this link http://www.fixya.com/support/t226674-zenith_p42w34_edtv_plasma_black_line
Jan 26, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
BLACK LINE
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
Mar 13, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Zenith P42W34 EDTV Plasma Black Line
Just reheat and add soder to fuse connected behing the driver boards.
Oct 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
1,088 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
