Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
HardDisk Hi all, I got a problem in my hardDisk. my HardDisk is 160G.suddenly it came 51G when i see it by the coms i see its size 160G but when i try to format it i see its size 51G. plz if you can help, Thanks
  • 2 more comments
  • Mody R.
    Mody R. Oct 14, 2008
    First, Thanks alot for your solution.
    I did that but it doesn't work, and i'm sure i don't have any bad in my hard becuse i checked it by the HDDregenerator and i didn't see any think.
    if you have any thing else.
    plz.
  • Mody R.
    mody2005 when you formatted the drive was there another partition made that you did not delete?
    No,I didn't
    Thanks for your careing
  • Mody R.
    No,I didn't
  • jason May 11, 2010
  • 905 Answers
Then you will have to go back and delete all partitions that were made to get all of the hard drive space for the operating system that will be installed on it
Posted on Oct 15, 2008
  • jason Oct 15, 2008
    and your very welcome!
  • 6,487 Answers
Just continue in formatting the hard drive because this can be cause by some malware that's why your hard drive is just showing that size and after you format it everything will be clean, the other reason why the hard drive is just shwoing that small size even though its a big size there's a possibility of bad sector on the hard drive so don't use the quick format when you reformat the drive so the bad sector will be fix also...
Posted on Oct 14, 2008
  • Mark Gil
    Mark Gil Oct 14, 2008
    Try first to scan the ahrd drive using a good anti virus like Avast and a anti malware software like Malwarebytes , this tow are good in cleaning your computer for some harmful worm, virusess and malware that can also cause this problem..those tow software are free so you can just download thme and use on your system....
    DOn't forget to rate the solution FIXYA thank you...
  • Mark Gil
My computor wont get to windos and declares opareting system not found. faliue. please contect me to idans84@gmail.com
Most times when this type of problem arise it always because the harddisk is damaged but on another hand you should try to format and reload your harddisk with another operating system first thereafter if the harddisk doesnt accept the installation of the Operating system then you can fanalise that the harddisk is dmaged and you need to buy another..
[pls remember to rate me
Jan 01, 2011 | Dell Inspiron Mini 10 Notebook
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
How do i fix the cannot find the correct hard disk problem in my PS3
Test you console with another harddisk to see if it detects the harddisk.
Also try a low level format on the harddisk with a pc so to ensure that there
is nothing left on the harddisk, when reinserted in the ps3, the ps3 needs
to fomat the harddisk, quick fomat will be enoug.
If the original harddisk is still not detected, then your harddisk is defective
and needs to be replaced, if the console also doen't detect the new harddisk then your ps3 needs to return to Sony because the sata controller on the motherboard of your ps3 is defective.
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Memory full due to photos in wrong drive
Hi! It seems that your out of harddisk space. That's why your computer memory also maxed out because your computer memory gets virtual space in your harddisk. Try to free up your harddisk or delete the unwanted files. GOOD LUCK
May 06, 2009 | Computers & Internet
MOBILE HARDISK IS 40 GB.HARDDISK PROBLEM IS DATA CAN NOT COPY FROM MOBILE HARDDISK OR PASTE IN MOBILE HARDDISK. HARDDISK SERIEL NO:-Q2KXOPE. HARDISK MANUFACTURING DATE:- OCT-06.
Maybe your hard disk is locked. Or kindly look at the properties of the Hard Disk see if the Read Only option is unchecked.
thanks
Mar 22, 2009 | Computers & Internet
BIOS cannot detect SATA harddisk
Most motherboards have multiple plug-ins for Sata drives. Try another plug in. This will typically solve this type of issue.
Dec 30, 2008 | ASUS P5LD2-VM Motherboard
Is it possible to restore from shadow copies of a crashed harddisk?
My harddisk crashed with lot of important files on it. I sent it to a trusted recovery service.
how can possible restore delete any file & folder on my pc harddisk
May 23, 2008 | Seagate Momentus 4200.2 100 GB Hard Drive
Slower, crashing, etc.
hi chinita...
u need to follow some steps..
step 1) click on start>run>type "prefetch"..
delete all the files that appear in the prefetch folder
step 2)click on start>run>type "%temp%"..
try deleteing all the files u can in %temp% folder.
also empty ur recycle bin
step 3) right click on my computer>properties>>advanced>>>click on "settings" under performance>>>again click on "advanced">then under virtual memory click on "change">>>set (custom size)initail size : 1024 &maximum size : 1024>> click on set >> then click on ok and then exit.
step 4)uninstall unessesary applications from control panel>>add/remove software...
Nov 03, 2007 | HP Pavilion a305w (DM181AR) PC Desktop
Boot Failure
boot failure could be the harddisk is bad or the os in the harddisk is corrupt, try installing a new os, if failure harddisk is bad.
uzowuanya
uzowuanya@yahoo.ca
Oct 21, 2007 | Toshiba 4030CDT (P000271450) Motherboard
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
186 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
