Question about Whirlpool Refrigerators
Changing interior light bulb in Whirlpool Frost Free 350,390 or 460 (per manual)
I have removed plastic cover for light bulb, as per manual supplied, but I cannot fit my fingers around light bulb to unscrew it. Is it clockwise or anti-clockwise and does the bulb actually screw into the white bayonet, or is that part of the overall bulb-structure? Not enough space to screw anything! Incidentally, I have a small hand and therewfore small fingers.
  • 750 Answers
Hello davvyde,
Welcome,
You said, you have removed plastic cover for light bulb, as per manual supplied, but I cannot fit my fingers around light bulb to unscrew it. Is it clockwise or anti-clockwise and does the bulb actually screw into the white bayonet, or is that part of the overall bulb-structure? Not enough space to screw anything! Incidentally, I have a small hand and therefore small fingers.
What is the model number of your appliance.
Is the bulb intact or did the glass part come off and leave the metal base inside?
IF YOU HAVE A PROBLEM TURNING OR GETTING THE BULB OUT, BEFORE YOU US ANY THING OTHER THAN YOUR HANDS, UNPLUG THE FRIDGE!
  1. Whirlpool bulbs screw out counter in the counter clockwise position.
  2. If it is screwed in very tight try a rag, or towel in your hand.
  3. Or you may try a rubber glove which causes friction and may give you a better grip.
  4. Turn off the fridge for a moment while you do this, in case the bulb breaks in your hand
  5. If the bulb comes apart from the metal base, (AND YOU HAVE THE PLUG OUT OF THE OUTLET) You may be able to gently use a needle nose pliers, to little by little loosen the bulb up if it is stuck
I've never seen this before in a fridge.
Let me know what works?
Huuum
Please remember to leave a rating!!!!
Posted on Oct 14, 2008
How to remove cover of fridge light to replace bulb
generally there is a Philips screw at the edge of the plastic cover,or sometimes you can squeeze or press in the sides of the cover.Check the make & model and go in line to the company,They usually will have a manual where you can find out the answer.Best of luck.
May 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to remove cover so I can change bulb
I think the best way to explain how to change the light bulb can be found on page 26 of the=> JFC2089HE User Manual If you have problems with the above link then click HERE and then enter your model number and answer the questions above the plaace you enter model number. I will be here to answer any questions you may have Thanks Sea Breeze
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download.
Dec 19, 2012 | Jenn-Air JFC2089HE French Door...
Whirlpool side by side GD25HAXNQ00 Light is out in fridge - including lights showing temp setting - it is not the bulb - what else can it be. Cooling is still fine with both fridge and freezer
you may need a board that is located on the rear of the fridge. pull the fridge out and unplug from outlet. locate the cover on rear and remove screws and open plastic cover. replace the board and new bulb. try this site and it is a bit pricey. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-electronic-control-board--item-number-ap4334000.aspx but to call a repair service it will be around 300.00
May 03, 2012 | Whirlpool Refrigerators
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Mar 21, 2011 | Kenmore 74889 / 74882 / 74884 Top Freezer...
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
HOW DO I TAKE OFF LIGHT BULB IN REGRIGERATOR SO I CAN CHANGE IT IT'S NOT UNSCREWING
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
Sep 30, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Light off
probably just the bulb. look in yoiur instruction book and it will tell you how to replace. usually just a matter of removing the cover over the light
Jun 08, 2008 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Refrigerators Logo
144 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
