Question about JVC GR-D33US Mini DV Digital Camcorder
Error message (safe mode)
Error message e03 i have the same problem
    Problem Solver:
  • 7 Answers
Day after thanksgiving, (year 2008) about to film my girls putting the tree and same E03 as all of you with the camera chewing my tapes. All of my DV cassettes are brand JVC so I know that was not the issue. I read and read and finally decided to grab a flashlight and study how the mechanism move. Then I noticed something suspicious about the right "two little spikes" attached to a white plastic piece that, when close, it moves to the right side of the camera head (the round stainless wheel inside). The white plastic piece mentioned above, part of it came off the guiding tiny little rail. 1. So I opened the tape compartment with an EJECT command, 2. Close it back up with an inmediate unplug of the camera without battery so it will stay in a position where I can get my fingers and paper clip inside. 3. With the paper clip, stretch the guiding rail in such a way that it widens so the bottom of the white plastic thingy can get back in the guiding rail. 4. Put a cassette inside and FFWD, PLAY or RWD and problem fixed.
Email me if you have any questions. Happy filming!
Posted on Nov 28, 2008
Can i get safeguard off
Posted on Oct 16, 2008
JVC DIITAL VIDEO CAMERA MODEL NUMBER GR-D3OU
Posted on Oct 14, 2008
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
When in play mode the following error appears E03 Remove and reattach battery unit in safe mode
As you have already removed the battery and re-attached it, try to clean the contacts between the battery and the camera.
I had tried this and it did not work so I tried Tapping on side of Camcorder ( gently on palm ) and I worked, after 2 or three times while message appeared.
Below are few reasons what causes E03 Error
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with each other, the tape is not wound because of overload to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette having no tape inside.
6. The tape slackens and no pulse is produced until the slack is taken up and the tape comes into the normal
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | JVC GR-DVL100 Mini DV Digital Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
to the mechanism.
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
HI MY MIN JVC GR D347 OPT800 RECORDER IS IN SAFE MODE AND I DISLOCATED THE BATTERY AND THE CORD AND ITS STILL IN SAFE MODE IS IT A RESET BUTTON ON IT HIDDIN
Dec 31, 2007 | JVC Video Cameras
Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
Oct 19, 2007 | JVC GR-DVL100 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
JVC GR-D33US Mini DV Digital Camcorder Logo
886 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
