Question about HP LaserJet 2550n Printer
Poor printing I have a 2550ln and it started to only print the right half of a page so I replaced the drum and ink but did not work so I cleaned everything and still no change could it be more serious?
  • 4 more comments
  • luannhayden Oct 28, 2008
    We are experiencing the same issue. It worked fine last week and now it is only printing the right side of the page. We also tried changing cartridges and the drum with no changes. Any help for a solution would be greatly appreciated.
  • tbahome Nov 09, 2008
    Same to me: Black only 3/4th of the page width, colour only yellow, and that very pale...
  • DSMURPHY147 Nov 11, 2008
    I HAVE THE SAME PROBLEM - I HAVE REPLACED EVERYTHING
  • bodforss Dec 04, 2008
    printing only the right half of the page.
  • judylong55 Feb 16, 2009
    I have an HP Color Laserjet 2840 that is having the same problem. I just refilled my toners. That is when it started. Wish I had a solution!!
  • iredbeard May 20, 2009
    tbahome,
    I had this model printer exhibit the same "printing on half the page" issue, and your solution was right on! Apparently after I replaced a defective imaging drum, the user brought it back to their office and it started to make a different grinding sound. I think one of the color toner cartridges must have gotten slightly out of place, which caused a jam, and the drive gear on the left side slipped a tooth.
Ok,
found a (the?) solution deep down in the web, and it worked for me: The four cartridges are hinged in a big gear wheel left and right of the printer. The wheel is driven by two small gear wheels sitting on a shaft abovee. It can happen that the gears jump one or two tooth on one side, then the cartridges are no longer aligned with the transfer drum (you can see the different gap size from top).
Solution: Take out the cartridges, the drum kit and the fixing unit. Select the black cartridge. Undo the power cord. Undo the side panels (screw at the bottom, then hooks). Take off the rear top panel at the printed paper bay (there are screw driver signs left and right, lift there. Do not try to lift this panel from the back side). Take a close look at the gear wheel linkage of the top cover at the right side, you need to reasemble this afterwards. Take off the top cover. Now you can see the shaft with the small gear wheels driving the big ones that carry the cartridges. When the black cartridge is selected, the two little notches on the small wheels must align with a pale stripe on the big wheels. You can bend the big wheels a bit to move the gears towards each other. You can turn the wheels when you lift the electromagnetic lock on the top right side. Once aligned, put back the top cover in place (with the linkage on the right side). Then you can start a test run after cartridges, drumkit and fixing unit are back in place.
Hope this helps you!
TB
Posted on Dec 04, 2008
  • 76 Answers
By what i am hearing from 5 different people it is a printer issue. But in saying that when i read the first one i was thinking that it may be the software or the way the computer has set the settings for that printer check your settings.
If you have any questions please dont hesitate to ask
Replacement ink
clean touch point of cartridge both side
Mar 31, 2014 | Pitney Bowes IMAGISTICS OCE IM3511,IM4511...
I replaced my black ink with a cheap brand that did not work. I then bought the expensive xerox ink and replaced it. I still get poor quality .. HELP
This printer is designed to print up to 50 000 pages trough its life. After that the transfer belt and the drum have to be replaced but the price is more than a new printer. So first check the counter (press the button and it will print it)
The cheap toner has entered in the black developing module where it mixed with the remained old original toner. They differ and tend to curdle. This is why printouts are poor after installing the new original toner. Try to print 20-50 black pages to take the curdled mix out. The developing module is part of the drum unit. It is hard to take apart and clean but not impossible. Buying a new drum unit is the last step, even after getting a new printer.
Aug 05, 2010 | Xerox Phaser 6110 Laser Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Hp laserjet Printer
There may be a release lever for the print head assembly which would allow you to remove the print head and clean the excess ink from it. If it appears to get better the more pages you print it may be just a matter of time and lots of pages before it cleans itself.
Try running the print head cleaning utility multiple times to help reduce the amount of ink on the print head. This could take quite a few times before it gets better.
Mar 10, 2008 | HP LaserJet 2550Ln Printer
HP LaserJet 2550n Printer Logo
344 people viewed this question
Ben Johnson
