TV Cable connector broken - Televison & Video
  • 30 Answers
If the tuner is not damaged many shops will replace it for you for $50. If you want to try to do it yourself you will have to remove the back unsolder the tuner and remove the sheilds then solder in a new RF connector and reassemble. If that helps let me know.
Posted on Oct 14, 2008
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
Broken cable connection on your TV?
Has the screw on connection for the cable on the back of your TV broken off or no longer usable? <br /><br />Here is a quick and inexpensive way to overcome a broken cable connector on the TV if it has RCA inputs available.<br /><br />Go to your local thrift store or look at Garage/Yard sales and look for an old VCR. Most VCR's have an option to connect to the TV with RCA cables and this will bypass the broken cable connection on the TV and save you that expensive repair shop bill and still keep your TV alive for a while longer.<br /><br />Hope this has helped you out and saved you some money.<br />Robert<br />
on Feb 26, 2011 | Televison & Video
The CATV connector on my Mitsubishi tv is broken off
This is the connector for the tuner. This repair must be done by someone who knows how to solder. But, if you have a Cable or Satellite box and this TV has AV connectors on the can use those and do not need to repair the TV tuner. If you do not have cable or satellite you can also use a VCR as a tuner. Just put the cable into the VCR and come out of the [VCR] AV outputs into the TV AV inputs.
Jul 06, 2009 | Televison & Video
I have a hatachi 60 rear projection tv, the cable port on the back of the tv is broken, i pulled the back off the tv and pulled off the silver box, the f-connector that goes to the incoming cable line, is...
This can be soldered back into the tuner if the board in the tuner is not broken. If you need a new connector any electronics supply store will carry it.
Apr 14, 2009 | Televison & Video
RCA F36676ET broken cable connector
expertize needed for repair any avg shop can repair min chg.
Dec 03, 2008 | Televison & Video
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Broken cable connector
Yes, its not that difficult. You may even find that you can salvage the one that you have. You'll have to unplug the TV and remove the rear cover. The connector may be located in the rear cover or a plate that sticks through the rear cover.
The connector may be attached to the TV's motherboard or a sub-board. It may even be just a bulkhead connector with a cable that is bolted to a plate.
Let me know what kind of "F" connector it is and I'll help you locate a replacement. Maybe you'll be lucky and just have to resolder the old one.
- Jim
Jan 31, 2008 | Zenith B27A11Z 27" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
Cable Connector inside TV
Unless you know how to sholder well and know how to do an isolation test on the set after its repaired I would let a pro do it My friend as I've seen it a hundred times. A peep will simply hook up a connector to the set and ground the connector or what looks like a ground and as soon as that set is pluged into an ac outlet and a cable or sat line is attached KAPOWWWWEEYYY.. It smokes and you end up blowing out the bridge rectifiers aong with all sorts of things. Now dont get me wrong please as you can repair set if and only if you wanna take that chance by simply taking a piece of coax cable with a connector on one end and soldering the center wire onto the broken wire that came off the connector and then soldering the outside or sheild wire to the place where the broken connector was attached if at all possible BUT I repeat this is not a good way to do this. Good luck
Mar 23, 2006 | Sanyo DS31590 31" TV
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
