Question about EliteGroup ECS 755-A2 Motherboard
The usb ports and the pci slots do not work
I have a ECS 755-A2 Motherboard In my device manager on the usb and the pci are all yellow. Can this be fix or not.
  • charroes Oct 14, 2008
    I have run the setup cd serval times nothing works also down loaded the drives from ECS nothing changed
  • 306 Answers
The most salient point is the yellow flag on the PCI. That means that the essential chipset drivers have not yet been installed. A specific driver will be ignored until your chipset drivers are found. That will be an executable file that runs for establishing the basic communications between motherboard components. ECS will have the original chipset drivers. If your operating system is not listed (you omitted that detail) then you may have use generic chipset drivers. Get those by reading the largest alphanumeric characters on the motherboard, do a Google search which will avail you of at least the real manufacturer of the mobo then go to the home page of that OEM or chipset manufacturer and enter the identifying numbers to obtain the chipset drivers. Run that and your computer will thank you. Remember -the chipset is what is not communicating, not specific drivers.
Posted on Oct 14, 2008
  • 6,487 Answers
Yes, this can still be fix, try first to run the setup CD for your ECS motherboard to reinstall the driver for those devices...if still not fix you may need to download the latest driver for your motherboard from ECS web site and update the driver for those devices..
  • Mark Gil
    Mark Gil Oct 14, 2008
    YOu can also try to disable and enable those two devices from device manager and also from the bIOS because sometimes this is a glitch with the BIOS , but if still the same problem there's a possibility that usb and pci slot are bad already...
    Don't forget to rate the solution FIXYA thank you....
My driver is almost damage can i get to download anew one
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Feb 11, 2011 | EliteGroup ECS N9400GT-1GDS-F GeForce 9400...
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
Jan 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Where can I fine manual for 755-A2 I went to EliteGroup www. No luck. Can you please HELP. Thank You
Try this:
Sep 26, 2010 | EliteGroup ECS 755-A2 Motherboard
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
ECS 755-A2 USB 2.0 no working
The best thing to do is uninstall the USB drivers on the machine and download off ECS the latest firmware and install.
Jan 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Motherboard 755-a2
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the web site what does it all mean.
Sep 03, 2008 | EliteGroup ECS 755-A2 Motherboard
Sytem wont post
remove the rct battery and try again power on again.
Also look for and replace bad cappacitors. If nothing works, you need a new momo!.317cfa4.jpg
Feb 12, 2008 | EliteGroup ECS 755-A2 Motherboard
ECS 755 A2- PC wont boot up with my X-FI sound card Extreme Gamer all i get is a black screen when turning pc with my sound card atached to mobo.
on most motherboards you have to install soundcards into the top or no 1 PCI slot if you dont it wont boot up. a lot of people install thier modem in that slot if yours is it will have to be moved to the bottom slot, this should fix your problem.
Jan 10, 2008 | EliteGroup ECS 755-A2 Motherboard
What's going on?
please check ur memory card it might not be inserted in the slot properly or might be fault with the memory card
Jan 03, 2008 | EliteGroup ECS 755-A2 Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
EliteGroup ECS 755-A2 Motherboard Logo
143 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
