Question about HP Officejet 5610 All-In-One InkJet Printer
Fax Duet Setup
I am trying to set up the OfficeJet for Fax Duet, over ADSL. If I set Auto Answer to ON, then phone calls are auto answered and the machine thinks it is a fax. If I set Auto Answer to Off, faxes don't come through automatically. I have set a distinctive Ring, and said I only have one phone line. I tried saying 2 phone lines, but incoming faxes were not received - disconnected.
  • Jill1234 Oct 14, 2008
    Would appreciate any assisitance whatsoever
    Novelist:
    Scholar:
  • 111 Answers
Not sure this will help but you could give this setup guide a try and see:
Setting up fax to use DSL
Post back your results, particularly if you need more assistance. Good luck.
Posted on Oct 15, 2008
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
When someone is trying to send a fax to me it just rings, and won't receive the fax HP OfficeJet 6110 All-In-One InkJet Printer
The auto answer function is not turned on. Here's how to do it ! Note the right arrow looks like > NOTE: The default Rings to Answer setting is 5 rings.
  1. Make sure Auto Answer is set to On .
    1. Press the Setup button (c01361401.gif ) on the control panel of the product.
    2. Press the right arrow button (c01185072.jpg ) to select Fax Settings , and then press OK .
    3. Press the right arrow button (c01185072.jpg ) to select Answer Options , and then press OK .
    4. Press the right arrow button (c01185072.jpg ) to select Auto Answer , and then press OK .
    5. Press the right arrow button (c01185072.jpg ) to select On , and then press OK .
    6. Press the Cancel button (c01235250.gif ) to return to the main menu.
Nov 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Will not accept incoming faxes
Have you set the Fax to Auto-answer or is it waiting for you to manually answer the fax? Change this by pressing Setup and Press 3, Press 3 again. Press the right arrow to toggle On or Off.
Make sure that the rings to answer is set appropriately. Press Setup 3 4 to change.
If you have a PBX or ISDN converter phone system, check that you are using the correct phone jack - for phones and faxes.
Do you have a voicemail service on the line? This will force you to receive faxes manually and only when you are present.
If you have an answering machine connected to the line, check that the answering machine is not the problem by disconnecting it and trying to receive a fax. Long welcome messages can make the calling fax machine hang up early. Insufficient time between the end of the message and the beep can make it impossible for the OfficeJet to spot the fax tones; the same is true with loud messages.
If this is the problem, record your message again, keeping it short (10 seconds but speak softly and slowly).
If you have a distinctive ring on the fax line, make sure that the OfficeJet is programmed to recognize the ring (some ring patterns cannot be interpreted and you'll need to contact your phone company to change it).
Check that other computer hardware is not causing an issue (modem with auto-answer, other interference). Unplug everything except the OfficeJet and try to receive a fax to check for interference. Then reconnect one item at a time and try getting a fax again to determine which item is causing the probelm.
I hope this helps.
Apr 08, 2010 | HP 5510 4-in-one Printer
How to set up fax number on my 7310 all-in-one.
According to the HP manual for this unit:
1. Verify that your HP all-in-one is set to answer fax calls automatically. (Press the Auto Answer button so the light is on.)
2. Press Setup.
3. Press 5, and then press 1.This displays the Advanced Fax Setup menu and then selects Answer Ring Pattern.
4. Press the down arrow key to highlight an option, and then press OK. When the phone rings with the ring pattern assigned to your fax phone line, the HP all-in-one answers the call and receives the fax.
You can download the manual from HP here if you've misplaced yours and need more setup information.
Apr 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
How do i gwet the hp officejet pro 7680 to get two short rings
To change the answer ring pattern for distinctive ring via the control panel 1 Verify that the device is set to answer fax calls automatically. 2 Press Setup. 3 Press Advance Fax Setup, and then press Distinctive Ring. 4 Press the right arrow button to select an option, and then press OK. When the phone rings with the ring pattern assigned to your fax line, the device answers the call and receives the fax
Mar 13, 2008 | Office Equipment & Supplies
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
202 people viewed this question
Ben Johnson
