Question about Hitachi DZ-MV350A DVD Camcorder
Can't get DVD footage off a RAM disc
I have a Panasonic DVD Camcorder (VDR-D100). I recorded footage of my daughter's first birthday on a DVD-RAM disc. I formatted the RAM disc on the recorder and then edited the footage on the recorder (dividing, combining files). When I put the disc into the computer to import the video using Panasonic's DVD-Movie Album SE program it said the disc couldn't be used, the format type was unknown and to insert an AV format DVD-RAM. This has never happened to me before, and of course it happens with my daughter's first birthday video! The file is saved in a DVD_RTAV folder, with the 3 usual files (VR_MOVIE.VRO / .BUP / .IFO files). Next I copied the files from the DVD-RAM onto my hard drive. When I try to access the files it says "Correctly copied recording video data doesn't exist in the selected folder. Select a DVD_RTAV folder that was copied using a copy tool." I can't tell from the outside what is damaged to not make it work property, and have been using RAM discs for the past year without an issue. Any help or suggestions are welcome!
4 Suggested Answers
  • 473 Answers
SOURCE: How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Posted on Sep 05, 2005
night71
  • 328 Answers
SOURCE: Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
Posted on Nov 18, 2007
SOURCE: Hitachi DZBX35E DVD Camcorder
I have the same problem never been able to even watch them in he dvd player. I need to get them on the pc. mine never came with the software
Posted on Jul 15, 2008
Hi..I have a Panasonic VDR-D160GN video camera. I only know the basics of its use. eg, I know i have to format/initialize a new disc and have to finalize it before playing it somewhere else other than in...
When i have had that happen to a customer i have had to replace the dvd drive assy to take of the problem. Your videos on your disc should still be retieveable once the drive has been replaced, also ask for any firmware updates for your drive assy. I hope this helps
Sep 04, 2010 | Panasonic VDR-D100 DVD Camcorder
Lost footage whilst trying to finalise a disc
problably not check disc in an other source , is this a disc brand you use before ?
Oct 31, 2009 | Panasonic VDR-D100 DVD Camcorder
Mini disc playback
Your computer probably wont read the disc, you may need to upload it. If you don't know how to do that I'd be happy to explain. Hope that helps.
Apr 12, 2009 | Panasonic VDR-D100 DVD Camcorder
icant finish downloading the software for the vdr-d100 because all it says you need to update
Oct 12, 2008 | Panasonic VDR-D100 DVD Camcorder
Transfering dvd ram disc to computer
try buying ulead videostudio and it doesnt even need to be finalized.
videostudio was great for me because i could simply put in my disc and then click on import from disc and it would import it onto my computer. hope that helps.
Aug 26, 2008 | Panasonic VDR-D100 DVD Camcorder
Panaconic VDR D100
im sure that your mini dvd will be readable with your dvd rom. if its not then try to use your mini dvd with your camcorder and use usb wire to connect it to your pc. install the cd driver came with your camcorder. use ulead movie maker to detect the camcorder and edit it to that. save it with any various types of videos that you like burn it with nero burner as a dvd disc.now you can watch it to your dvd player. hope that helps!
CHARCOIS
Aug 22, 2008 | Panasonic VDR-D100 DVD Camcorder
Panasonic DVD Palmcorder (VDR-D100) 1.5 yrs old will not power up
Nope men... I have Just the same problem... I have a VDR-D105 and suddenly doesn't turn on... i was recording with a full charged battery and suddenly just turn off... forever :S
Jun 04, 2008 | Panasonic VDR-D100 DVD Camcorder
Changing the mode to use USB on panasonic VDR-D100 DVD camcorder...
Try using only DVD-RW disc (not DVD ROM/-R/+RW) and format as "Video" mode. When you are done shooting finalize the disc. Then iMovie or your movie maker should recognize the video.
May 05, 2017 | Panasonic VDR-D100 DVD Camcorder
Hitachi DZ-MV350A DVD Camcorder Logo
150 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
