Question about LG Studioworks 45 14" CRT Monitor
Characters are scrambled
IC in the monitor got damaged. I got replaced the IC with its accessories after tuning. When I connected my monitor with the PC, the characters are not displaying properly. The characters are not clear. Please suggest what to do.
  • 348 Answers
Check connections of R.G.B.and 15 pins to end thenif ok then check positive Vcc at the ic on crt base if less than 12v then check regulater ic if faulty replace it display also can be corrected by adjusting ring magnets on yoke coil
Posted on Nov 23, 2008
LG LCD IC damaged
it would be cheaper to just replace the screen. The cost of the IC and equipment to install it again would cost way more and also would require to program the chip and the codes are almost impossible to get
Sep 08, 2013 | LG Computers & Internet
Sony ericsson EP800 USB+5V charger IC SO8 is burned and I can't detect the part number
Just get another on EBAY. It's not worth messing with versus expense. Ya, it probably could be fixed, but hard to find a schematic for it.
Dec 10, 2012 | Sony Ericsson EP800 Power-Saving...
My Coby 32 in tv won't store my channel memory. When I first got the tv, it stored the channel memory but now I have to reprogram it every time I turn it on.
Hello
When autotuning the set goes throughs all transmitting channels, shows to be receiveing all channles, but seems to be tunes indefinitely, and no channels are locked, the memory IC inside the set has got damaged. In normal case, the TV will tune to all available channels at that tiime, in air or through the cable, whatever the case may be, tune up to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels.
The memory IC i stated above is a small IC with 8 terminals, and can be located very near to system control Ic, at system control section. In some sets, it will be SMD type [Surface Mount Device], and in otheres will be of DIL type [Dual In Line]. If it is a DIL type, it is very easy to replace. If it is SMD type, proper care should be taken when replacing it, not to damage any track on circutit board and nearby components.
Open your TV, locate the IC and desolder it out of the printed circuit board, go for a same type and number, replace it. This will solve your problem.
OK.
Jan 18, 2011 | Coby TFTV3225 32 in. LCD TV
The picture is scramble
I see the pictures, you need new screen, the LCD panel is cracked, sorry for the bad news! The screen will cost more tahn the new monitor.
Jun 07, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Blank screen on Thinkpad Lenovo T61, when I connect a monitor and reboot it shows scramble.. help
Your video card adapter might be damage. Or you have installed a wrong driver for your laptop.
Another cause of the problem is your RAM or memory might be damage. I suggest you buy a new memory to test it.
Thanks. Cheers!
Apr 21, 2010 | Lenovo ThinkPad T61 Notebook
Retress line with vertical foldover
Vertical suddenly fold over? Vertical IC loosing connection with board. Best solution is to reflux or resolder it. If not damage vertical IC, replace it. That should fix the problem.
Apr 13, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Ghosting of the image
no it is a board replacement at best, so i would look into replacing the vga board or getting a new monitor and selling the damaged one for parts with the issue listed
May 11, 2008 | Acer AL2216W LCD Monitor
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
LG Studioworks 45 14" CRT Monitor Logo
65 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
