Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba that doesn't refrigerate
We just moved into a place with a KitchenAid Superba that probably was not used at all over the past year. Everything about it appears to be working, the motor is on and we can feel some cool air in the bottom, but inside the refrigerator is not cold. We've moved the temperature settings to no avail. Not sure if there's some kind of master switch you can flip when it's not in use, but we feel a little stupid not knowing what to do.
Thanks.
  • classcat1977 Oct 31, 2008
    Went on vacation. Came back and fridge was on but everything in the fridge & freezer was rotten. I pushed the temp. control to the coldest & it seemed as though the motor kicked in, but no cold air. I pushed in the button that the door closes to turn off the light & the motor stopped.
    Now I have a huge boat anchor in my kitchen. If you have found out what to do - please let me know! THank you
    Catherine
  • 120 Answers
Cathe if compressor is not running nothinh will get cold specially if frezeer is not working then the other side wont etheir if compressor is not running then it might just be the overload if nothing is running just the lights the is etheir the timer or thermostat
Posted on Nov 03, 2008
Water filter on kitchenaid superba not snapping into place
The entire filter with cap attachment must be in place or the water will not be filtered.
Feb 27, 2014 | KitchenAid Superba Architect KSCS25INSS...
My kitchenaid superba refigerator will not cool
Try vacuuming/cleaning the coils behind the floor grill.
Jul 14, 2010 | KitchenAid Superba Architect KSCS25INSS...
Door doesn't self close on Kitchenaid Superba frig
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jul 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a 25 ft Kitchenaid Superba, probably 5 years old or so. It just started to get a large buildup of frost/ice on the surfaces where the ice maker tub joins the ice chute in the door. I have taken the...
There may be a small leak in the pipe at the place of joint which lets small amount of water out and it may be this water that freezes. Have a check of that tube and if necessary get it replaced.
Apr 20, 2010 | KitchenAid Superba KSRG25FK Side by Side...
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Over temperature alarm on KitchenAid Superba Refrigerator
Remove the screws from the bottom grill cover. Use a vac brush to clean out that area. You should also pull the frig out from the cabinet and vac behind.
Also, you can go on kitchenaid.com and download a product manual to replace your lost manual. Click on customer care and select "Locate Manuals & Guides."
Mar 31, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
244 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
