Question about Fuji Cameras
How to replace battery in a Fuji DL-200 - Fuji Cameras
    Sergeant:
    Champion:
  • 334 Answers
What luck! Today I was browsing a local thrift store and bought it for 99 cents. It looked like it might have a nice lens. I nearly gave up on finding the battery compartment, but finally figured it out. You need to open the back cover completely. There is a little silver arm that prevents it from opening all the way. You can gently pull back on the silver arm where it attaches to the the body. It will pull away from the body and allow you to open the back all the way. The battery I found was a Panasonic Lithium CR-P2 6V. I hope that helps.
Posted on Oct 14, 2008
My fuji fine pix s9600 drianes the life out of the battery with in minits is there a fix
This is from the What Digital Camera review (quoted for the purpose of review only)
'When it comes to playback things are a little less satisfactory, with a noticeable delay scrolling between images and the battery life using regular AA cells is disappointing - a set of copper-top Duracells expired at around the 200 frame mark, which may be OK for a day's shoot, but NiMH rechargeables or Energiser Lithium cells are preferable.
Read more at http://www.whatdigitalcamera.com/reviews/compact-cameras/fujifilm-finepix-s9600#l6gtyijBLdtVH9HI.99
So, looks as if you need high power batteries, or else re-chargeable cells. Normal cheapo-cheapo ones will drain rapidly.
Nov 18, 2016 | Fuji Cameras
How do I fix the tele/wide button?
You'll probably need to take it to a repair expert because the internal component needs to be replaced. Because of the age of the device, lack of replacement parts, it will be hard to find someone who is capable of doing it. Might want to consider an upgrade/replacement.
Jun 23, 2015 | Fujifilm Dl-400 Tele 35mm Film Camera Auto...
WHAT TYPE OF BATTERY
They are all the same size at least the last 200 i can remember were
SONY CR2032 Equivalent CMOS battery
Mar 05, 2014 | Acer Aspire T180-UA381B AMD Desktop PC -...
What film to put in a fuji DL-95 camera
The DL-95 uses standard 35mm film. You can use slide film or negative film (prints). You can use color or black-and-white. It's your choice.
Jan 04, 2013 | Photography
Usb drivers for finepix av 200
Do you really want a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 07, 2012 | Fuji Cameras
Looking for fuji circuit breaker cat. eg103a
I need replacment circuit breaker fuji model# eg103a 100A
200-415 V .Thanks. Andre
Dec 13, 2010 | Fuji Electrical Supplies
Fujifilm S3100 won't power on
I'm not familiar w/ the S3100 but do you see any corrosion in the battery terminals? These camers don't usually just quit working. If the terminals are clean, what battery are you using? How many mA or milliAmpere rating? These are usually indicated on the rechargable battery's sides. There are some new battery in the market. The eveready silver colored battery. I forgot the name. It is one notch above the regular alkaline battery. Let me know if this helps.
Jul 20, 2008 | Fuji FinePix S3100 Digital Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Fuji S3500 won't turn on
Acording to the manual, if a camera is stored for a period of time, you need to insert new batteries and leave the camera for an hour or so. I had the same problem, and after an hour the camera worked. AH
Oct 11, 2006 | Fuji FinePix S3500 Digital Camera
Cameras Logo
61 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
